HELP! engine swap
Old Oct 15, 2008 | 04:07 AM
Slows2k's Avatar
If you've got a 06 DBW engine, you'll need to swap the cam sensors, valve cover, crank sensor, and crank sensor reluctor to get the car to start on a stock PCM. You'll also need the intake manifold with original throttle body.
When you do get it running you'll have air injection DTC's because the DBW cars don't have the air injection ports machined in the cylinder head.
Old Oct 15, 2008 | 10:29 AM
armthehomeless's Avatar
Used old crank sensor and cam sensor, have old valve cover on there too.
Air injection DTC's?
Air injection is hooked up, and I'll leave the ducting off.
I want to remove the air injection system completely, but I've heard it throws the cel if there is no electrical load on the system.
Old Oct 15, 2008 | 02:56 PM
Slows2k's Avatar
If you still have a 06 and later cylinder head air injection isn't going to work no matter what. There are no ports for the air to go into the exhaust machined in the head.
Slows2k's Avatar
You also need to verify the cams are installed correctly, it won't run if either camshaft is out of time 1 tooth.
Old Oct 16, 2008 | 12:39 PM
PGM-fi relay was bad, thanks 03 ap1
Awaiting delivery of relay at this point.
chris_barry's Avatar
Do the 06 engines use the same chopper plates for the cam/crank sensor pickups? Do these need to be carried over with the pre-06 sensors?
Old Oct 16, 2008 | 05:34 PM
Slows2k's Avatar
The plates/reluctors are different. Only the Exhaust cam has a sensor on it for DBW cars.
Old Oct 18, 2008 | 08:19 AM
Have AP2 cams in,
engine was assembled by a honda guy, who's worked on s2000's
I'll call him Monday to make sure, but he did ask for my AP1 cams.
Old Oct 20, 2008 | 07:51 AM
JDMwhiteS2K's Avatar
I am having the same problem...
Old Oct 20, 2008 | 01:51 PM
Wrong cam plates.
Thank you Slows and Chris.
