Injectors
Old Nov 24, 2008 | 11:19 AM
scottieboy561's Avatar
Default Injectors
just got off the phone with rc injection they told me i can run a 750 cc saturated injector without a resinator box. is this true or would it be better to go with 1000cc peak and hold and a resinator box and if so what box do i get
Old Nov 24, 2008 | 11:26 AM
s.hasan546's Avatar
why didnt u just put that question in your other thread about injectors?
https://www.s2ki.com/forums/index.php?showtopic=650386
Old Nov 24, 2008 | 11:28 AM
gotswap's Avatar
Yes those will be fine. Make sure to get the spacers and injector harness.
Old Nov 24, 2008 | 11:34 AM
alright thanks i wasnt sure if i needed a resinator box or not.i am also going to lower the compression before the tune but i think i will go with the 750cc saturated injectors because i wont need more than 500 hp for a while
Old Nov 24, 2008 | 11:37 AM
gotswap's Avatar
750's may be a touch to small depending whether or not that is 500 crank or 500 whp. Thye should be good to just above 400 whp before needing to upgrade.
Old Nov 24, 2008 | 11:48 AM
no 500 crank
Old Nov 24, 2008 | 11:49 AM
gotswap's Avatar
you will be fine, make sure your tuner watches the duty cycle.
Old Nov 24, 2008 | 12:28 PM
ChefJ's Avatar
whats a resinator box?
Old Nov 24, 2008 | 12:32 PM
gotswap's Avatar
resistor box
Peak and hold have a lower resistance then the stock saturated injectors. Running peak and hold without a resistor box will fry your injector drivers in the ecu.
Old Nov 24, 2008 | 12:35 PM
Soul Coughing's Avatar
it cuts down on drone when you haven't refilled your VTECH fluid
