engine breaking vs breaking
Old Mar 19, 2009 | 12:04 AM
agentRak's Avatar
Default engine breaking vs breaking
i rarely use engine breaking entering corners or to stop.. i think it's not too healthy for the motor. however rav matching 'down shifting' is what i do most, if not netural breaking.. easy on the clutch and motor. maybe you can benefit from this too.
Old Mar 19, 2009 | 12:13 AM
CarpetedConsole's Avatar
in before the grammar police
Old Mar 19, 2009 | 12:22 AM
ahrmike's Avatar
Well, the way I see it..
If you're engine breaking, you have a car left. If youre just 'breaking, you're eithier break-dancing or you broke your car?
Anyway, engine brAkeing is recommended (and the license test people will fail you if you dont) because its dangerous to suddenly drop it into a gear and not revmatch -> the 'shock' could make you spin out if you do it noob-ly enough.
People also do it while racing since its faster than neutral-ing into a turn, then having to revmatch while coming out of a turn. ->drop gear, revmatch, engine brake while braking, then as you come out of turn, youre in the right gear, etc etc.
'revmatching' and letting off the throttle already means youre engine braking!
Old Mar 19, 2009 | 04:48 AM
takeshi's Avatar
I don't see much benefit in breaking your engine or breaking the car in general.
Braking, on the other hand...
Old Mar 19, 2009 | 04:53 AM
speedworksracing's Avatar
Old Mar 19, 2009 | 05:23 AM
dedonderosa's Avatar
i do both...... sometimes i just brake and other times i engine brake but i see it this way.
whats cheaper to replace???
Brakes or a Clutch??
Old Mar 19, 2009 | 05:56 AM
thebig33tuna's Avatar
this thread is destined for epic failure.
use the search function
https://www.s2ki.com/forums/index.php?showt...ndpost&p=661250
https://www.s2ki.com/forums/index.ph...pic=58074&st=0
etc etc etc
Old Mar 19, 2009 | 06:01 AM
Saki GT's Avatar
No one here wants to break their engine.
Jamie_Murray
Mar 8, 2010 04:39 PM
alcxm5
Aug 12, 2009 11:12 PM
Talavah
Apr 17, 2009 10:36 AM
zero_to60
Jul 31, 2003 04:59 PM
BlueIrishS2k
Jan 18, 2003 07:21 AM
