Retainers and keepers
Old Apr 27, 2009 | 12:20 PM
03BlkS2k's Avatar
Default Retainers and keepers
Anyone know of a place/someone to get my ap1 retainers and keepers swapped with ap2's? Thanks.
Old Apr 27, 2009 | 12:41 PM
FF2Skip's Avatar
Yes. Billman250.
Old Apr 27, 2009 | 12:49 PM
robrob's Avatar
Daisy Import Auto near Lisbon on I-70 about 15 miles west of Baltimore. The owner, Ben Schaefer is an ex-Honda racer and did my engine swap. (301) 854-6252. The retainer replacement is a pretty big job because the head has to come off, but I highly recommend you get it done--a broken retainer destroyed my engine.
Old Apr 27, 2009 | 01:06 PM
03BlkS2k's Avatar
Originally Posted by FF2Skip,Apr 27 2009, 03:41 PM
Yes. Billman250.
Yes, my first choice was Billman, but he's up there in NY. I didn't want to drive up there and have one of of my retainers crack and i'll be sol.
I misshifted this past weekend going from 3rd to 2nd. granted, i was doing about 61-65 in 3rd, and then downshifted, but I don't want to take any chances.
I called a few shops but the labor was a bit pricey.
Old Apr 27, 2009 | 01:10 PM
goldenfri's Avatar
, I had mine done here a while back at george (gfactor)'s recommendation. So far no problems, but yea it is very expensive.
Old Apr 27, 2009 | 01:12 PM
FF2Skip's Avatar
IIRC, with the right tool(s), the replacement can be done with the head in place. Also, I think you can use a compressor's air to keep the valve up through the spark plug's position. It's been so long since I've thought about this stuff that I just can't be fo' sho'.
for trying to prevent a bigger problem.
Old Apr 27, 2009 | 03:00 PM
S2KinVA's Avatar
I did the retainer replacement at around 60k and according to the advise of Hardtop Guy he didnt recommend the AP2 retainers because of the difference in RPM limit. just a thought...
Old Apr 27, 2009 | 03:10 PM
PoLe_PoSiTiOn's Avatar
what is the avg price of getting this done? because I have heard its a good thing to have done for the AP1 and want to get it done to mine soon.
Old Apr 27, 2009 | 06:57 PM
robrob's Avatar
A leak down tester can be used to pressurize the cylinder to hold the valve up, but you have to have a special valve spring compressor designed to be used with the head on to remove the keepers and retainers.
Old Apr 28, 2009 | 04:47 PM
03BlkS2k's Avatar
has anyone had some valve work from inlinepro? I got a pretty fair quote from them.
