Noob needing help with stereo problem!
Old Jun 4, 2009 | 09:10 AM
mikehaze's Avatar
Default Noob needing help with stereo problem!
Hi all! I've only been an s2000 owner for a few days now; I bought the car used, but in great condition. There's only one problem; the stereo will not play!
The previous owner installed an aftermarket head unit and as far as I can tell, just factory speakers. The head unit itself works, power comes on and all. I can change the audio settings and pop in a cd, only no sound comes out of the speakers(NONE of the speakers are playing sound). The speakers made a popping/crackling sound when I picked the car up, but has not made the sound since.
What could it be?
Old Jun 4, 2009 | 09:49 AM
DFWs2k's Avatar
check the fade and balance, if everything looks ok there, pull out the radio and see how it is wired
Old Jun 4, 2009 | 10:52 AM
crazydude's Avatar
This is a long shot... but I am gonna throw this out there...
Perhaps he had a amp installed in the car somewhere that fed the door speakers. Perhaps the amp was removed 10 min before you showed up to buy it???
Any power cables attached to the battery under the hood?
Old Jun 4, 2009 | 10:54 AM
mikehaze's Avatar
I even reset the head unit and all of the settings are at default. When I turn the volume up, the speakers have a very audible buzzing that gets louder. I checked the wiring and it all matches up. Everything has power and seems to work, yet no sound. I don't get it.
Old Jun 4, 2009 | 11:04 AM
crazydude's Avatar
fuse blown on the headunit?
Old Jun 4, 2009 | 11:32 AM
mikehaze's Avatar
I don't think the HU would work at all then. I have no idea.
Old Jun 4, 2009 | 04:21 PM
DFWs2k's Avatar
do you have another h/u you can swap out with?
Old Jun 4, 2009 | 05:53 PM
mikehaze's Avatar
Got it. The driver side lower speaker was mounted on with a mdf bracket that had broken in half. Basically, the speaker shorted out and apparently the head unit to short as well.
orella13
Jun 21, 2011 05:36 AM
brainlessAP2
Feb 21, 2011 06:47 PM
clarence35
Jul 9, 2007 07:47 AM
craigowens
May 29, 2006 07:05 PM
su2ny
Jun 20, 2003 07:20 PM
