"Only oil temp facts"
Old Jun 6, 2009 | 05:45 PM
az3ar's Avatar
Default "Only oil temp facts"
I am posting this thread to gather as much info as possible about oil temperatures on the track I am not interested in street numbers but actually hot track days with truly pushing the car.
Today I have hit the ~265 oil temps on Mobil 1. This is a track S2000 with no AC and stripped out.
What are you guys seeing out there?
Old Jun 6, 2009 | 09:29 PM
Billj747's Avatar
Kinda hot. 250+ isn't ideal and starts to thin the oil out. It will start to break down and blow stuff up at 300*F if not before that. Try to get it below 220 with an oil cooler.
Old Jun 6, 2009 | 09:59 PM
az3ar's Avatar
thats what I thought... oh well this car requires more work than my Spec E30
Old Jun 6, 2009 | 10:00 PM
az3ar's Avatar
I was on street tires not even Rs, 205 front and 225.
Old Jun 6, 2009 | 10:42 PM
Billj747's Avatar
I don't quite see the correlation between oil temps and tire size/compound. Regardless, get an oil cooler!
Old Jun 7, 2009 | 10:04 AM
SpitfireS's Avatar
Sorry, no facts just questions.
Where did you measure oil temp?
What was the coolant temp at the time?
There is a small OEM oil-to-coolant heat exchanger behind the oil filter, so the coolant shoud be high too when you see 265F oil.
How is the air flow through the radiator?
Old Jun 7, 2009 | 04:06 PM
az3ar's Avatar
What I mean is: Rs = faster laps = more load on the engine = higher temps. I could be wrong but that
Old Jun 7, 2009 | 04:09 PM
az3ar's Avatar
From the Greddy sandwich between the filter and the block.
I don
Old Jun 7, 2009 | 06:26 PM
Billj747's Avatar
[QUOTE=az3ar,Jun 7 2009, 04:06 PM] What I mean is:
Old Jun 7, 2009 | 07:57 PM
Js S2k's Avatar
[QUOTE=az3ar,Jun 7 2009, 08:09 PM] From the Greddy sandwich between the filter and the block.
I don
