building the bottom end
Old Jun 26, 2009 | 02:34 AM
Spnshfirefighter's Avatar
Default building the bottom end
taking my block in for a hone while installing an f22 crank and bearings along with 2.2 crower rods... was planning on using the existing pistons (f20 version) if possible... im really trying to avoid purchasing another 700 in parts... is an issue going to arise with clearance if i leave the old pistons in? anyone here swapted the 2.2 parts in an ap1? just trying to get everything in order before the motor goes to the machine shop... please help (ill be slapping on my fully built head post return of block)
Old Jun 26, 2009 | 06:23 AM
LostMotion's Avatar
Your compression will be bumped to the 11.8:1 range.
Old Jun 26, 2009 | 07:49 AM
EVAN&MONICA's Avatar
umm a stroker build is something you may want a large budget for; are you sure this is something you want to do, right now?
Old Jun 26, 2009 | 09:07 AM
ABCVTEC's Avatar
Its not that much of a stroker. He's just putting an AP2 crankshaft in an AP1 block with aftermarket BC rods and OEM AP1 pistons. Clearances will be fine, just using the AP1 pistons will result in increased compression.
Old Jun 26, 2009 | 12:55 PM
compression goes up ... does this mean i will need a tune for timing? can i rev to 9k? do i need a piggyback system?
thanks for the help
Old Jun 26, 2009 | 01:47 PM
S2Kage's Avatar
oh you can rev to 9 k, plenty of 2.2s do it but shit will wear out faster, from what im told the wrist pins cant hold up to the increased piston speed.
But hey while ur at it you might as well get aftermarket pistons.
wadzii
May 30, 2011 01:30 PM
lookinco
Oct 15, 2010 03:51 AM
motowiz27
Apr 12, 2010 06:38 PM
0piston
Jan 11, 2010 06:30 AM
Inlands2k
Socal Swap Meet
Aug 8, 2007 12:41 AM
