Vibration Under Hard Acceleration
I just bought an 02 S2K with 125K miles on it. It runs well but I have noticed a vibration under hard acceleration. Any time I get it above 4 or 5 K it vibrates but if I lift my foot off the accelerator the vibration stops.
The tires on it are cheap -just good enough to pass inspection- tires but could that be the cause of my issue. Thanks for any insight.
Also, any other major concerns I should be thinking about with a high mileage S2K? ow many miles will an AP1 motor go before major issues.
Is the car lowered? Or was it lowered and now back at original ride height?
If so it may be the inner CV buckets. Here is a thread to help understand what may be going on:
https://www.s2ki.com/forums/index.php?showtopic=693173
I'm not dismissing that the tires may be the issue as well...but normally if the vibration is only on accel, it is a good indication that the CV buckets are the problem.
Originally Posted by S2Kitt,Sep 9 2009, 12:52 PM
could the "CV Pit theory" be the cause of it too if there was vibration at normal highway speeds? but not as noticable at lower speeds.
Originally Posted by booski,Sep 10 2009, 10:22 AM
i was wondering the same, cause thats how my car is. only at about 80mph.
IIRC it is only under acceleration.Might check drive shaft flang bolts.
