Vibration Under Hard Acceleration
Old Sep 5, 2009 | 06:22 PM
jss5246's Avatar
Default Vibration Under Hard Acceleration
I just bought an 02 S2K with 125K miles on it. It runs well but I have noticed a vibration under hard acceleration. Any time I get it above 4 or 5 K it vibrates but if I lift my foot off the accelerator the vibration stops.
The tires on it are cheap -just good enough to pass inspection- tires but could that be the cause of my issue. Thanks for any insight.
Also, any other major concerns I should be thinking about with a high mileage S2K? ow many miles will an AP1 motor go before major issues.
Old Sep 5, 2009 | 07:38 PM
negcamber's Avatar
Is the car lowered? Or was it lowered and now back at original ride height?
If so it may be the inner CV buckets. Here is a thread to help understand what may be going on:
https://www.s2ki.com/forums/index.php?showtopic=693173
I'm not dismissing that the tires may be the issue as well...but normally if the vibration is only on accel, it is a good indication that the CV buckets are the problem.
Old Sep 5, 2009 | 09:01 PM
viper_driver's Avatar
I'm with negcamber. It's rear CV joints. Mine did the same thing, replaced them and the vibration totally went away. good luck.
Old Sep 7, 2009 | 01:45 PM
jss5246's Avatar
Thanks I was thinking it could be CV joints, especially with that many miles on the car.
Old Sep 7, 2009 | 01:46 PM
datdude1119's Avatar
My sister had the same thing on her 4runner.. and she just got it fixed and it was a cv joint
Old Sep 9, 2009 | 12:52 PM
S2Kitt's Avatar
could the "CV Pit theory" be the cause of it too if there was vibration at normal highway speeds? but not as noticable at lower speeds.
Old Sep 10, 2009 | 10:22 AM
booski's Avatar
i was wondering the same, cause thats how my car is. only at about 80mph.
Old Sep 12, 2009 | 09:04 PM
omgitsoop's Avatar
cv joints here too......
Old Sep 12, 2009 | 11:55 PM
BLkAP1's Avatar
Yeah, sounds like your CV joints are experiencing pitting.
I just fixed the same problem by installing T1R Drive shaft spacers. Another cheaper option is to swap the CV's to the opposing sides.
Good luck!
Old Sep 12, 2009 | 11:56 PM
Fast Jack's Avatar
IIRC it is only under acceleration.Might check drive shaft flang bolts.
nastinupe1
Nov 29, 2007 08:49 PM
00redS2k
Dec 11, 2006 07:47 AM
Johnny Sack
Sep 27, 2006 06:45 AM
i_heart_my_DB8
Apr 25, 2005 04:16 PM
SuperDyu
Apr 13, 2004 10:09 AM
