Official S2000 CR Owners Thread Part II
Old Nov 14, 2009 | 12:47 PM
Mocky's Avatar
Default Official S2000 CR Owners Thread Part II
Old Nov 14, 2009 | 12:49 PM
DanZilla's Avatar
Post #2
https://www.s2ki.com/forums/index.ph...ic=547802&st=0
Old Nov 14, 2009 | 04:12 PM
Mchester's Avatar
To answer your question regarding the CR right rear fender/SPO... (Side Panel Outer)
I have not seen that die myself, but stampings dies are often made up of many individual parts bolted together on a base to make one side of a die for one panel. Parts on the die are replaced when needed to make sure panels are nice and accurate and scrap is minimized. I would assume, to produce the CR Delete rear panel they would just replace that section that produces that blank with a flush piece on both sides of the die. This would be relatively easy to do for very little cost.
Unfortunately, the process for forming the trunk trim panels is not so easy or cheap to modify, so I'm sure it was a simple cost based decision to leave that panel alone.
Old Nov 14, 2009 | 04:26 PM
Mocky's Avatar
makes sense... do many CR owners just take that piece out then since there is nothing really behind it. I would like to see about making a flush piece in the same material. Would add a little more trunk space as well and not leave a gapping hole... not a big deal... just a thought.
Old Nov 14, 2009 | 04:38 PM
jeggy's Avatar
took mine out and left it out. the extra room pays off when i go grocery shopping.
there were times when sonia had to carry bags on her lap when in the AP1. that doesn't happen anymore in the CR.
Old Nov 14, 2009 | 05:14 PM
Mchester's Avatar
My plan is to make a piece that would utilize the extra space but block off the driver's side where the fuel tank/sender are located.
Old Nov 14, 2009 | 05:27 PM
DanZilla's Avatar
*sigh* I really want to own a Apex blue CR...
Old Nov 15, 2009 | 10:00 AM
CKit's Avatar
I was half-thinking about painting our AP1 Apex Blue...
Old Nov 15, 2009 | 01:17 PM
b1indsamurai's Avatar
What we need is a CR subforum
Old Nov 15, 2009 | 01:48 PM
AsL_RaCiNg's Avatar
If you are in Ontario, Canada I would sell you mine.
