Your Next S2000 Build
Old Dec 31, 2009 | 10:47 AM
dsddcd's Avatar
Default Your Next S2000 Build
Okay, I thought this might be fun and informative, so I will start.
If I knew then what I know now I would have..........
Year.........................2008-2009 CR (No Wing)
HP Goal.....................400WHP
Color........................Blue
Daily Driver or Toy....Toy
Hardtop or Soft..........Both
SC / Turbo................Supercharger
Kit Manufacturers.......Vortech / Tuner
SC / Turbo Size.........V3 SCI Trim (Larger Impeller)
Header/Manifold.........T1R Header
Cat (Y or N)...............Yes, High Flow Mini Spool
Rear Exhaust.............Asura or Factory w/ Cutout
Intake Pressure.........(+/-) 15 PSI
Fuel Pump.................Walbro Pump w/ Voltage Booster
Fuel Injectors............ID 1000cc
ECM/Piggyback..........Flash Pro
Clutch.......................ACT or Centerforce
Rear Diff...................Quaife
Gear Ratio.................Factory
Transmission.............Factory
Cylinder Head............Factory w/ AP1 Cams
Other........................UR Air to Air Intercooler, Innovate Wideband & Pyrometer
Suspension:
Shocks.....................Factory
Springs.....................Factory
Sway Bars................Factory
Wheels.....................AP2 V1 or BBS RGR's
Brakes.....................Wilwood 4 Piston Fronts with Stock Rotors and Steel Lines
Other........................None
Interior:
Head Unit..................Factory w/ Ipod Input
Speakers..................Factory
Seats.......................Factory
Shifter......................Factory
Gauges.....................None
Body:
Front Bumper.............Factory
Rear Bumper..............Factory
Side Skirts..................None
Headlamps..................LED Eyebrow
Tail Lamps..................Factory
Top Type....................Factory HT
Other..........................None
Other Thoughts:
Old Dec 31, 2009 | 11:05 AM
circuitclub's Avatar
Active Streak: 30 Days
The only thing I would've changed are my wheels. I would've chosen more aggressive offsets. Instead of
17x8.5 +58 I would get 17x9 +~50
Old Dec 31, 2009 | 11:06 AM
camuman's Avatar
hmm, interesting. i hate to say it, but i woulda went for 500whp instead of 400whp lolololololol.
hoping to fix that in 2010 with some sort of blower upgrade. if i can fit it, a tvs1320 would be bery bery nice
Old Dec 31, 2009 | 12:31 PM
KnowledgeIsPower's Avatar
If i did it over again....
Whatever gets me to 450WHP in the most reliable manner. Don't care if its SC or Turbo - I just want to get in the car and drive.
K-Pro for emission purposes.
949 17x10" wheels
and enough gauges/ 1 serial to monitor everything
Old Dec 31, 2009 | 12:48 PM
JoeyBalls's Avatar
I did it wrong the first time, thats why this time i am taking my time and building my car EXACTLY the way I want. As far as Exterior I may paint the bumper but I love the Work Wheels and OEM hardtop with the AP2 Lip
My Turbo build is going as planned, just costing a ton of money
Old Dec 31, 2009 | 05:09 PM
berlinas2k2's Avatar
Time to buy a porsche j/k
Old Jan 1, 2010 | 12:47 AM
goldsS2000's Avatar
If I could do it over again I would just take my time with one setup instead of literally buying and reselling 6 damn configurations. Im afraid the exhaust whore-ism just cannot and WILL not ever be cured. I did find it interesting that you said oem shocks springs and not so much sway bars. Have you had aftermarket springs or coilovers and just prefer stock the stuff?
Old Jan 1, 2010 | 08:18 AM
Skatethesea's Avatar
I am happy with my build. It was good to go from stock to 305whp with the VTSC. This March is 400whp. If that isnt enough, I will wait til 2011 and drop the cash on a 550whp turbo kit. But it is good to go in increments so that I dont get jaded by just going to 550whp and not knowing the inbetweens.
Old Jan 1, 2010 | 09:05 AM
Raven628's Avatar
If I knew what I know now, I would have waited a while longer.
I put the Inline Pro turbo kit on my car in 2004. At that time they did not have a oil relocation kit. So I had a shop make one for me and they used dash 12 lines which led to starving oil pressure. Spun number 4 rod journal.
Then I decided to go stroker. Only TODA had a stroker kit. I still have the kit. Used a shop in Miami to sleeve me a Darton closed deck block. Was that a disaster. That block went through three builds and at least six HG changes.
Finally found a Benson sleeved block lieing around. It was bored to 89mm. So now I have a 89.5 mm bore with CP pistons with a TODA bottom end.
Precision turbos, well I am now on my fourth. If the 6262 goes out, I am done with Precision. Their warranty extremly sucks. Customer service is extremly lacking. Only reason I bought another one is because I had a credit to use up, so saved a little money.
I love my Apexi gauges with AEM Uego. I learned just to solder so you don't have a bad ground. Crimps suck.
All in all it has been an expierence. I could have been spared a couple of bad times. With crap going wrong.
I am just glad everything is working out. I just check on everything; bolts, mounts, fluids.
Here is to a much better decade.
Old Jan 1, 2010 | 09:17 AM
camuman's Avatar
what shop in miami did u use?
