spark plug TSB is now a recall
Old Aug 10, 2002 | 10:25 AM
wanabe's Avatar
Default spark plug TSB is now a recall
my dealer performed the spark plug TSB and indicated that it is now a recall...
they now replace the plugs with a different size plug. i dont have the old plug info anymore (they covered it up in my manuals with the new info- with stickers), but the new ones are:
NGK PFR7G-11S
DENSO PK22PR-L11S
does anyone know enough about spark plugs to recognize the diff between these and the ones that came with the car?
i wonder why they had to change...
Old Aug 10, 2002 | 10:57 AM
S2K Power's Avatar
I assume this only for OEM plugs right? If we replaced the OEM plugs with different ones we don't need this fix?
Old Aug 10, 2002 | 11:04 AM
wanabe's Avatar
good question...
i would guess that you do need to change them, since they were put in to replace the old size plugs, and the plug size (?) has changed- i see that the new plugs have a different torque pressure than the old ones...
i assume that you need to make sure that your plugs are compatible with the new ones indicated in my previous post.
Old Aug 10, 2002 | 02:08 PM
Utah S2K's Avatar
Just got my recall notice today. The notice says it has to deal with the spark plug gasket. Original part number was: NGK PFR7G-11. The "S" means stailess gasket (per NGK data). . The recall says there is a possibility the engine light may come on due to misfire....guess they don't want to mention you can blow your motor .
Utah
Old Aug 10, 2002 | 06:10 PM
wanabe's Avatar
interesting utah...
they change the plugs and even make us chage the owners manual to reflect the correct plugs (new size). i know that the TSB said it was for gaskets, so its interesting that they are also changing the plugs!
Old Aug 10, 2002 | 07:36 PM
airgate's Avatar
Well this is exciting. The only other recall was for the seatbelt.
Old Aug 11, 2002 | 12:06 AM
yu888's Avatar
i think they decided on changing the plugs all together with teh gasket ring to minimize future issues. i am sure its not that much more of a cost issue to just take care of it now, vs having to deal with bad plugs later.
I would think that those who already changed the OEM plugs with something else only need check the torque setting used (18# vs the 13# listed in the manual)
Old Aug 11, 2002 | 05:07 AM
jelliotlevy's Avatar
[QUOTE]Originally posted by wanabe
[B]my dealer performed the spark plug TSB and indicated that it is now a recall...
Old Aug 11, 2002 | 05:09 AM
That DENSO plug is PK22PR-L11. Let me not add to confusion by my bad typing.
Old Aug 11, 2002 | 05:13 AM
Utah
Ignore my posting. Thank you, Utah S2K. I think I took 2 Stupid Pills rather than 1 first thing this morning.
