what is stock timing
Old Feb 28, 2010 | 12:59 PM
S2SEXY's Avatar
Default what is stock timing
i need to know stock timing by rpm
if someone has this info please just post if its ap1 or ap2.
i want to know how much advance the timing is from 4k-9k
i know somewhere near 8400 the stock ecu lowers timing about 6 degrees
Old Mar 2, 2010 | 01:29 PM
scareyourpassenger's Avatar
I wouldn't want to run stock timing unless I knew how much the knock maps backed it off. That being said. The stock numbers inside the ecu would be a bad starting point. You are better off logging via odb and using those numbers as a base.
Old Mar 2, 2010 | 07:19 PM
S2SEXY's Avatar
i can check it using my emanage but im already boosted and not sure if its retarding timing
Old Mar 17, 2010 | 07:14 PM
thesilverbullet's Avatar
stock timing for ap2 at WOT
3-5.5k: 29-28 degrees
8.5k+: 28-27 degrees
so, 4-9k at WOT the timing will be advanced as much as 29 (in the lower rpm range) and will drop to 27 degrees in the higher rpm range -
note this only applies to WOT conditions...
Old Mar 18, 2010 | 06:08 AM
Gernby's Avatar
Timing for the AP1 is probably not as agressive as it is for the AP2.
Here is the stock timing curve for a totally stock '06 (blue) compared to a nearly stock '08 (red). The lines at the bottom represent knock retard. I don't know why the '06 had so much more knock retard. Note that these datalogs were done when barometric pressure was between 950-1000 mBar. At higher altitudes, timing would be more advanced.
Old Mar 18, 2010 | 07:51 AM
Kyushin's Avatar
Banned
WoW 27 degrees... I wasnt crazy then on my last baseline to see 27-29 degrees. Explains the mild knock I was getting, way too damn high underboost right?
Old Mar 18, 2010 | 02:44 PM
S2SEXY's Avatar
thanks for the info
as you can see at 7800 timing starts to fall off.
im having a similar results with my ap1 where the timing is dropping from 8400-9k
Old Mar 22, 2010 | 02:23 PM
myflys2k's Avatar
dont want to jack the tread but whats a good obd2 scan tool to get that logs timing and knock?
Old Mar 24, 2010 | 05:26 PM
jonbar87's Avatar
I use the scanguageII...it doesn't really "log" it necessarily, but you can monitor pretty much every parameter your stock ecu puts out. Then, what I do is, drive around with rpm, load, tps, and ign timing on the screen and then record it with my phone. Then I go back and play/pause the video and copy the values into AEM appropriately. That's how I made my basemap for my prelude. Runs great. I realize this is an s2k forum with the F20/22, but the H22 has similar ignition values. Here is what my stock map looks like:
this is with base timing set to 16*
stantaur
Jul 26, 2015 01:30 PM
stantaur
May 18, 2015 12:21 PM
passmans2kny
Jun 22, 2014 05:33 AM
maluch
May 20, 2010 05:58 PM
HiRpmVTEC
Mar 22, 2009 09:20 PM
