Another air pump thread.
Old Mar 12, 2010 | 12:22 PM
B5254T4's Avatar
Default Another air pump thread.
I´ve been searching but no real answers, a few people wrote that they will try to fool the ECU but no result how it went.
Done this in other car brands and normally pretty straight forward after reading the diagrams. Any idea of the signals going back to the ECU? A certain resitance? Voltage?
Anyone here tried to solve it?
Old Mar 12, 2010 | 12:25 PM
s2k aok's Avatar
a vendor sells the air pump delete kit in the sponsor section, last i knew...
Old Mar 12, 2010 | 12:36 PM
B5254T4's Avatar
IIRC they didn´t finish it. Can´t find the thread but think so.
Old Mar 12, 2010 | 12:38 PM
goldenfri's Avatar
Yea it doesn't work for USDM cars. There is simply no easy way to do it.
Old Mar 12, 2010 | 12:43 PM
B5254T4's Avatar
Hmmm... Gotta find some electrical diagrams and start looking in to it. Got a broken pump and refuse to buy a new one, always nice to clean up the engine bay as well.
Old Mar 12, 2010 | 12:46 PM
goldenfri's Avatar
Here is the thread for the one GT motoring was selling.
https://www.s2ki.com/forums/index.php?showtopic=711974
We are deeply disappointed that we won't be able to fix the issue due to few reasons.
Our unit works ALL-region S2000 except US spec.(which means our unit works on Canadian spec)
Not only US spec S2000 has totally different circuit to control/monitor air pump, it also has different ECU programming to monitor air pump operation(air flow).
Our fix kit was be able to by pass the circuit, but not the ECU programming.
We were trying many different ways to by pass the programming(air flow) last 3 weeks but no luck.
We found this issue very last minute while we were doing long term testing on US spec S2000.
The operation is monitored by oxygen sensor at start up which is almost impossible to bypass the signal/ECU programming due to several circumstances.
Once our original unit is installed on US spec S2k, it causes slight electricity usage even with ignition off due to ECU won't shut off at all.(ECU stays on all the time)
Because ECU does NOT check for air pump operation at first start up after the ECU reset, our unit deleted CEL but ECU kept stay ON.
(However, this is NOT the way it suppose to work. We have tested on other regions S2000 and it works just fine.)
As I said few weeks ago, this kit was originally designed based off euro spec S2000.
After we were done testing on euro spec S2000, we tested on US spec S2000s before the release.
We confirmed that it worked(as it is describe above) which was hard to notice any issue in short period.
Now I really wish it showed some issue right away, not like this....
If you are driving S2000 as a daily, you shouldn't have much issue because ECU only draws very small amount of electricity.
But all buyers are free to get refund.
Once again, we are very sorry to bring this news.
We apologize about all this hassles and issues.
Old Mar 12, 2010 | 12:56 PM
B5254T4's Avatar
Thanks, a bad one but still a start.
Old Mar 12, 2010 | 01:00 PM
suzuka-blue-s2k's Avatar
There is no way around the airpump. The one way to get rid of it without the CEL is if you have an aftermarket ecu, or management system. If you dont wanna spend that much, just fix or replace whatever needs replaced.
Old Mar 12, 2010 | 01:06 PM
goldenfri's Avatar
It really is ridiculous how much Honda charges for a replacement air pump. I see them pop up for sale from people who went EMS. That is probably your best bet.
Old Mar 12, 2010 | 01:20 PM
B5254T4's Avatar
I need an EMS with OBD still working because of the inspection here. On the same time I just hate crap in the engine bay and don´t want to buy stuff that´s not needed for the engine health.
I´ve removed working pumps on my older cars just to clean up and get rid of hoses.
"No way around the air pump" might be true but worth a try, wont cost anything to try? Got a few really good engine tuners to help me out and if I tell them there´s a market for a simulator they might want to spend some time to solve it.
But I know, it´s probably impossible.
blixhavn
May 9, 2013 08:16 AM
Floppy
Nov 11, 2011 04:36 AM
rob2.2
Jul 23, 2011 03:30 AM
hshiznit
Jun 28, 2010 09:47 AM
sbrodacz
Mar 3, 2009 06:55 PM
