Air pump delete
Old Jun 27, 2010 | 07:34 AM
hshiznit's Avatar
Default Air pump delete
The air pump has stopped working (code P 0410) and id like to just get rid of it. Will i be able to do it without it sending a code? Will it effect the ecu? IF i can remove it, how is it done. Thanks
Old Jun 27, 2010 | 07:37 AM
suzuka-blue-s2k's Avatar
The search button could give you an answer in like 3 seconds. Ill be nice though You can get rid of the air pump, but you WILL have a CEL. People have tried to make a delete kit, and it didnt work. The only way around the CEL with the airpump is if you have an EMS. So its not even nearly worth it. Just post in the Want to Buy section on here to buy a new air pump. There are alot of people that have them and dont need them anymore. I had to replace mine also, its not to hard to change. The biggest part is taking the front bumper off.
Old Jun 28, 2010 | 09:47 AM
hshiznit's Avatar
I appreciate it . i did a search but didnt see anything..i may be looking in the wrong area. Thanks for the info!
Kevin
dsthez
Dec 2, 2012 06:02 PM
Floppy
Nov 11, 2011 04:36 AM
Simann
Jul 30, 2010 06:06 AM
gilgothdae
May 5, 2010 09:39 AM
dsthez
Mar 16, 2010 12:17 AM
