Please Help
Old Apr 25, 2010 | 07:27 AM
JSWhaler's Avatar
Default Please Help
Over the last few days my car has been acting up. My check engine light has been on solid NOT flashing. The engine seems to be bogging i.e. when I push the gas the acceleration delays and feels that the ECU is trying to cut out the fuel. Thus far I have done the following:
replaced my plugs
replaced the O2 sensor
Replaced MAP sensor
Reset ECU & cleared codes and seems to drive normally for about 1/2 hour then it all comes back.
Please help this is driving me nuts.
Code P0172 which I belive menas my engine is running too rich.
TPS% 5.0
Engine Rpm 1013
Calc load 62.3%
MAP KPA 63
Coolant 174 F
IAT 159 F
ST FIRM 1 -27.8
LT FIRM 1 -19.0
ST FIRM 3 -100
LT FIRM 3 -100
I realize this is probably better suited for under the hood, but I'm looking for quick help.
Old Apr 25, 2010 | 07:34 AM
ScottyBallistic's Avatar
Is this with or without the E-manage ?
Old Apr 25, 2010 | 07:37 AM
JSWhaler's Avatar
Both, even after taking out the EManage, it still does this.
Old Apr 25, 2010 | 07:44 AM
JSWhaler's Avatar
I got the engine light to go off (wiped ECU) drove for 10 mins and was still off so I installed the Emanage and ran it, then the light came back on after 1/2 hour. Uninstalled Emanage and engine light stays on. Car does what I said it does in first post.
Old Apr 25, 2010 | 07:51 AM
Disconect the battery for 1/2 hr and remove the emanage . Then connect it back and drive it for a few days without the EU . 10min is not long enough for the computer to learn or to throw a code . It takes driving cycles . Just drive it normal , Nothing agressive so it stays in Closed loop to set the fuel trims .
After that plug in your scan tool again and look at the fuel trims . and tell me what you find
Old Apr 25, 2010 | 08:22 AM
JSWhaler's Avatar
Thanks, I'll give it a try and let you know what happens.
Old Apr 25, 2010 | 10:11 AM
HARDtoTOP's Avatar
Try the map whack. That seems to fix everything
Old Apr 25, 2010 | 04:31 PM
IMP's Avatar
IMP
My ce light disappeared after a valve job they were so out of whack.
Old Apr 26, 2010 | 02:55 PM
Any luck ?
Old Apr 26, 2010 | 03:56 PM
JSWhaler's Avatar
It's been raining here and the S is my weekend car i.e. haven't driven it yet. I'll be sure to let you know what happens.
