Window Creases...my observation
Old Feb 25, 2001 | 07:58 PM
redleader's Avatar
for a while now, many s2k owners have known about the damages the folding rear window can cause, namely, the crease that begins to form in the middle. Hence, the fabric covered tube that many of us use, or have made or bought. However, I have observed my top opening process very closely and have concluded this; I don't really see the window "folding" on itself. Rather, the crease or "line" that forms comes from the middle strut on the top coming down on the rear window, after it has folded, and rubbing against it as it comes to a rest at the end of the opening process. Therefore, the "line" actually forms in the lower portion of the window, and not directly in the center. I've made my own tube, using a pool noodle, with extra fabric to stick out (as instructed on S2Ki.com) and have noticed that the tube portion doesn't really do much, rather, its the extra foot or so of fabric which prevents the outside of the center strut from rubbing against the window. Now, as for the inside of the window, a Muz mat or similarly constructed piece of fabric will do wonders from keeping the inside scratched. But I just can't see the window actually "folding" on itself (with or without the tube).
What do you guys think?
Old Feb 25, 2001 | 10:46 PM
lvs2k's Avatar
I guess that may be why I've had so much success with a simple terrycloth towel tucked inside the top where it overlaps the rear window on three sides (top + either side). The towel not only protects from the strut, but also keeps the window from getting scratched. The outside of the window is fully covered and protected.
Old Feb 26, 2001 | 04:56 AM
wirejock's Avatar
I made my own tube too. No crease problem.
Old Feb 26, 2001 | 06:15 AM
Mavic's Avatar
[QUOTE]Originally posted by redleader
[B] I don't really see the window "folding" on itself.
Old Feb 26, 2001 | 09:55 AM
STL's Avatar
STL
[B]I've made my own tube, using a pool noodle, with extra fabric to stick out (as instructed on S2Ki.com) and have noticed that the tube portion doesn't really do much, rather, its the extra foot or so of fabric which prevents the outside of the center strut from rubbing against the window.
Old Feb 26, 2001 | 03:03 PM
redleader's Avatar
too bad there wasn't an easier solution, tube, cloth, or towel, we still have to get out half way through the closing process to put something there as it comes down. Thats a royal pain in the ass.
Old Feb 26, 2001 | 03:05 PM
Big Al's Avatar
Mine had a crease where it folded and was in the upper part of the window in the very spot that I see through the rear view mirror. It also rubbed where the strut laid on it when it was down. Thanks to a very patient wife and seamstress and through trial and error, I came up with a noodle and integrated matt made of terry cloth which solves the crease and the rub.
These photos show the final version which I have been using for about 4 months. It is essentially a noodle with a mat attached. The mat is tucked in between the window and the canvas at the edges and this holds it in place while the roof is lowered. I also have a mat on the inside in the roof well where the window lays when closed. With this solution all surfaces are protected. It solved the crease that I had previously in the upper part of the window. It also provides protection from the strut rub and scratching.
Atlmike
Oct 22, 2001 10:08 PM
dean29
Apr 21, 2001 05:27 PM
Zeke
Mar 22, 2001 11:41 PM
