Mase Engineering 6262B Build Thread
Old Jun 2, 2010 | 08:24 PM
dsddcd's Avatar
Default Mase Engineering 6262B Build Thread
Well here is all I have for now when I have a chance I will start to fill in the details
List of Parts & Changes
Mechanical
Mase Engineering Manifold
Precision 6265SP Ceramic Bearing Turbo - S Cover - 0.70 Compressor / 0.63 Hotside
Mase Eng 2.5" Intercooler Piping
InlinePro/Precision Intercooler (600HP Core 2.5" Piping)
Precision 44mm Wastegate
Mase Eng St-Stl Dump Tube Recirced into Downpipe
Custom Oil Drain System (-10AN Tapped in the Front of the Pan)
Mase Eng Turbo Oil Feed (-3AN w/ NO Restrictor)
Tial Q BOV
DEI Titanium Turbo Blanket
DEI Hose Sleeve for Coolant Lines and Turbo oil Supply
Custom Made St-Stl 430 Heat Shield
Asura 3” St-Stl Exhaust w/ Revised Intermediate Pipe
62mm Berk Test Pipe
ARP Hardened Exhaust Studs
AEM Dry Flow Filter w/ Custom 4" Coupling
5 Star T-bolt Clamps
Extra Tompside 02 bung
Gasket Matched the Exhaust Manifold to the Turbo Gasket
Custom Welded IC Brackets
PatS4P Flexible AC Relocation Lines
HD PCV Valve
All New Extruded 1/4" ID Silicone Vacuum Tubing
Throttle Body Coolant Bypass
Contoured and Sanded Pistons
New Thermostat
AP1 Intake & AP2 Exhaust Cam
Innovative Motor Mounts
BKR8EIX Gapped to 0.023"
Factory Coil Packs
SOS Ported Throttle Body
Fuel
Injector Dynamics 1000cc Injectors
AEM Fuel Pressure Regulator
InlinePro Fuel Rail
Walbro 255LPH Pump
Custom -6AN Dual Fuel Supply Lines
Jegs St-Stl Fuel Pressure Gauge
Fuel Pump Voltage Stepper/Regulator ste at a constant 15V
Jegs -6AN Inline Fuel Filter
Cylinder Head
Mild Head Porting
Gasket Matched to Intake and Exhaust Manifold
Ferrea Intake and Exhaust Valves
InlinePro Valve Springs and Retainers
New Valve Seals
Sealed the Air Injection Ports
Decked the Surface
InlinePro 3mm Head Gasket
Electrical
AEM 30-1052-U Fuel Management Unit
AEM Serial Gauge
Custom Pillar Mounted Led and Buzzer Warring Indicator
Modifry ECT Fix
Modifry Seal Belt Lock (It is SWEET)
GM Air Intake Temperature Sensor
Omni 4 Bar Map Sensor
About 18 Miles of Wire
Serial Splitter to Allow the Serial Gauge to Operate and Have a Tuning Port
Custom Made Battery Relocation Kit
Industrial Trunck Mounted Enclosure
One Gauge Supply
100 A Breaker
New Trunk Cover Plate
AEM (MAC) Boost Solenoid
Drivetrain
ACT HD Pressure Plate
Factory Clutch Disc
*Not Installed*
InlinePro R200 Differential Kit w/ Drive Shaft Shop 2.9 Axles & Drive Shaft and Nissan Viscous Differential
Mahle 8.9:1 FRM Compliant Pistons
Testing
Custom Coil Packs
AP1 vs AP2 Exhaust Cams
Factory Exhaust w/ 3" Sound Performance Cutout
Old Jun 2, 2010 | 08:25 PM
dsddcd's Avatar
Well here is some of the progress so far.
dsddcd's Avatar
Old Jun 2, 2010 | 08:30 PM
D1sclaimer's Avatar
Horsepower Wars?
Lookin good man.
Old Jun 2, 2010 | 09:12 PM
boostftw's Avatar
Old Jun 2, 2010 | 09:16 PM
JspecVtec's Avatar
beautiful
Old Jun 2, 2010 | 09:19 PM
Spoolin's Avatar
Very nice man! Cant wait for the results.
Old Jun 2, 2010 | 10:10 PM
MaseEng Nick's Avatar
good to see you got it all in one piece!
Old Jun 3, 2010 | 06:15 AM
camuman's Avatar
in for updates. any idea of completion date?
Old Jun 3, 2010 | 06:21 AM
Irishflame27's Avatar
what kinda power you shooting for? looks awesome!
