Mase Engineering 6262B Build Thread
Old Jun 28, 2010 | 08:07 PM
  #101
Suzuka_Joe's Avatar
Originally Posted by TRBOKEV,Jun 28 2010, 07:53 PM
After I shut my car down I can hear the turbo continue to spin for close to a minute after.. That's hot with no oil pressure.
thats interesting. i'll have to listen for it
Old Jun 29, 2010 | 09:16 AM
  #102
dsddcd's Avatar
My old BB turbo did the same as did the new one at the beginning.
Old Jun 29, 2010 | 09:21 AM
  #103
neeman77's Avatar
So you are getting the center section replaced on your turbo then?
Old Jun 29, 2010 | 10:22 AM
  #104
dsddcd's Avatar
Yes, one way or another I need it back here by the July 9th which is when Mase is coming to tune it.
Old Jun 29, 2010 | 11:28 AM
  #105
wait4vtec's Avatar
what is needed to datalog aem series 2 on my laptop, i am about to download the program
what cables do i need and where do i hook it up on the aem?
Old Jun 29, 2010 | 11:38 AM
  #106
camuman's Avatar
need either a usb cable or a serial cable that is long enough to reach from ecu to your laptop and be comfy. then install program, start it up, connect to ecu, and choose window you want to datalog. push F6 i think it is, and boom, logging. i choose the tuning window, has lots of good info on there.
Old Jun 29, 2010 | 11:45 AM
  #107
wait4vtec's Avatar
so just a regular usb will work!? i dont need a serial to usb adapter or anything?
Old Jun 29, 2010 | 12:02 PM
  #108
dsddcd's Avatar
With the Version 2 a usb cable it it, just make sure it is a printer cable. Also you will probably need to manually install the USB drivers
Old Jun 29, 2010 | 01:37 PM
  #109
Ben-NSI's Avatar
Use the DB9 cable, way less bugs that way.
Old Jul 2, 2010 | 06:47 AM
  #110
dsddcd's Avatar
Well, got some good and bad news.
1.) Precision found the problem, there was a small piece of aluminum in the internal 0.035” restrictor. Based on what they could tell this starved the turbo of oil and caused bearing failure. This would explain why the turbo sounded good and was okay initially, as it was getting oil just not nearly enough. They agreed to have the cost of the repair for me and will have the unit back by early next week.
I was hoping that it was their issue and still wonder how metal got in the feed line but they were very helpful and professional. Precision FTW
2.) With the turbo off I noticed that I could see the diaphragm on the WG through a little hole. Turns out there are (2) vacuum ports on the lower portion of the Precision wastegate. So that you can choose a different location depending on the manifold design. If the turbo would not of come off I would have never found this.
3.) On my new build I used all 1/4” ID vacuum hose vs. the 1/8” I used in the past in hopes that I would have better BOW and Boost control operation. Anyway long story short I did not want to use zip ties on the hoses as the just embrittle over time and fall off. I went to the local hardware store and found spring clamps that are used for low pressure fuel lines that fit perfect. They also had a nice brass Tee fitting, I hate the damn plastic ones they just can’t take the heat.
So now all I really have left to prepare for my tuning day is to install my fuel filter, get a new air filter, and look at getting a turbo oil feed filter.
