Compression in our engines...
Old Sep 3, 2002 | 11:28 AM
S2K's Avatar
S2K
Default Compression in our engines...
What should the compression be in our cylinders??? I recall someone saying it should be within 180-200psi and all 4 cylinders should be within 10% of each other...is this correct???
Old Sep 3, 2002 | 12:13 PM
Sumtoc2's Avatar
Honda manual says:
Nominal = 228 PSI
Minimum = 135 PSI (hope not....)
Max variation between cylinders = 28 PSI
Old Sep 3, 2002 | 03:56 PM
Bieg's Avatar
Just had mine checked when my mechanic did the plug recall. Wanted to see how it broke in and make sure the #4 cylinder was not wearing. Lowest 225 - Highest 230. Had the valves done at the same time.
Old Sep 4, 2002 | 07:19 AM
Gernby's Avatar
Does the manual say whether to check the compression when the engine is hot? I would expect that a hot engine would give more consistent readings.
Old Sep 4, 2002 | 07:33 AM
S2K's Avatar
S2K
Is a compression test the same thing as a leakdown test???
Old Sep 4, 2002 | 08:59 AM
Bieg's Avatar
No. In a leakdown test they pump the cylinder up with compressed air and measure if it leaks down past the rings or valves. A Compression test measures how many pounds of air the individual cylinder/piston is pumping when it is cranked over.
Old Sep 4, 2002 | 09:59 AM
marcucci's Avatar
Your cylinders should always measure within about 2-5% of each other, anything in excess of about 10% indicates a problem. Anything that is 10% lower than stock also indicates a problem. The results of a compression test generally go up with age (on a car in good health) as the carbon deposits on the piston usually increase compression slightly.
Compression on a brand new motor is usually lower, due to improper (incomplete) sealing of the rings. Anything below maybe 7,000 or 8,000 miles will be lower.
Old Mar 14, 2009 | 11:41 AM
w1ngman's Avatar
Thought I'd drum up an old thread...to speak to compression on an 'old' S2000 AP1 motor ... Today I competed a compression test on The Bruised Banana's motor (to-date: 193,300+....hard-to-average-driven miles).
The results:
Cylinder #1 = 261
Cylinder #2 = 255
Cylinder #3 = 255
Cylinder #4 = 255
All readings were performed twice on each cylinder, and compression test was performed in manner mentioned above: Pulled all plugs...pulled fuel pump fuse...and with clutch & gas pedals all the way to the floor, cranked the motor over numerous times [actually my mechanic cranked it 12 times per cylinder check as that is his SOP at the Honda shop] testing one cylinder at a time.
I plan to perform this test again with a different compression gauge (sort of an 'objective' testing if you will) to assure his gauge wasn't faulty, etc.). I'll try to report back here again once I do that.
Overall, I'm very pleased
- Dave
TvoS2K
Feb 1, 2021 05:31 PM
s2kadvent
Feb 16, 2015 08:43 AM
Elistan
Sep 7, 2012 08:22 PM
Moddiction
Jun 20, 2008 08:53 AM
FormerH22a4
May 31, 2005 08:23 AM
