Clutch changes biting point
Old Mar 14, 2009 | 11:33 AM
Nickamsweet's Avatar
Default Clutch changes biting point
It seems that when i first start the car up the biting point is about half way through the pedal... then once the car has warmed up then it's right near the top of the pedal travel... do i just need to get the thing replaced? because it's starting to do my head in now...
Old Mar 14, 2009 | 11:47 AM
mlc's Avatar
mlc
A couple of things. First check the amount of fluid in the clutch reservoir. Here is a good DIY on bleeding the clutch but it will help you http://forums.s2kca.com/showthread.php?t=12154. If it is low or dirty I would bleed the clutch. Also check inside the car under where the clutch pedal is. If you see fluid there then the clutch master cylinder is gone bad. Here is a DIY on replacing it http://forums.s2kca.com/showthread.php?t=15696.
You have a MY00 so it is not that uncommon to have to replace.
Kevin
**EDIT**...XVIPER He is the man..
jhkim161
Oct 4, 2014 02:07 AM
Jag528
Jan 24, 2012 03:21 PM
S2K.Danny
Aug 24, 2011 08:46 PM
Dragon Slayer
Dec 7, 2007 05:56 AM
s2kev
Apr 9, 2007 01:07 AM
