Head Bolt Retorque w/ InlinePro 3mm Gasket
Old Jul 5, 2010 | 03:36 PM
dsddcd's Avatar
Default Head Bolt Retorque w/ InlinePro 3mm Gasket
So, I have the car nearly ready to get tuned on Friday and I am trying to get finished up however I keep thinking about the head gasket. On my previous build the head gasket manufacturer SCE recommended that I retorque the head bolts after heat cycling. InlinePro however did not make mention of this in the instructions for the new gasket.
Is there a need to retorque? Being that the factory headgasket does not require/recomend it I am inclined to say no but it only takes an hour so if it won't hurt I will do it.
Also the new head studs that I installed from ARP had noted in the instructions that the nuts be torqued to 95 ftlb where as another set I installed on local members car only required 85 ftlb per the instructions. Did anyone else notice this?
Old Jul 5, 2010 | 03:43 PM
m R g S r's Avatar
so the same model of headstuds from ARP required different torque numbers? you sure one wasnt with oil and one wasnt with the lube? i think i did hear something about ARP releasing new torque numbers for some of their studs. btw i think i did mine to 95....
Old Jul 5, 2010 | 04:23 PM
siadam's Avatar
I don't believe in re torquing.
I've NEVER done this on anything I've put together and NEVER had a headgasket failure.
Old Jul 5, 2010 | 04:28 PM
JoeyBalls's Avatar
Not threadjacking, but somehwat related, Where do I get "Molly lube" I heard I need it with the ARP Headstuds, Ia m trying the over my prematurely failed OEM
Old Jul 5, 2010 | 04:36 PM
siadam's Avatar
It's moly lube, and I think I picked some up at Advanced, or Auto Zone.
I'm sure you can order it from Summit/Jegs as well.
JoeyBalls's Avatar
cool thanks
Old Jul 5, 2010 | 04:38 PM
ghettocrxsi's Avatar
Almost any auto parts store will carry molly lube joey, And I also have never retorqued a set of studs.
Old Jul 5, 2010 | 04:57 PM
JoeyBalls's Avatar
thx
Old Jul 5, 2010 | 05:02 PM
chad86's Avatar
didn't re torque mine either. so far so good.
Old Jul 5, 2010 | 05:51 PM
teamvalorracing's Avatar
never re-torqued here either.
