FlashPro 06 Greddy turbo results
Old Jul 7, 2010 | 11:52 AM
Hondata's Avatar
Default FlashPro 06 Greddy turbo results
Here are the tuning results from a FlashPro tuned Greddy turbocharged 06 S2000. Thanks to Brian (ConeKiller) for the 4 hour drive to have his car tuned.
Right click here and Save As to download calibration S2000 Greddy calibration
Car specifications:
- RC 550 injectors
- Berks High Flow Cat
- Invidia exhaust
The chart compares it to our stock 06 S2000 (dotted green line) on the same dyno.
Tuning notes:
- We are at the limit of the 550 injectors - 91% duty at 8300 rpm.
- We are also at the limit of the MAP sensor.
- A test pipe will add about 15-20HP.
- A stock cat will subtract at least 30 HP.
- Ignition timing was quite low to prevent knock. There will be gains if tuned for a higher octane fuel.
More boost & power requires a replacement MAP sensor and bigger injectors. This calibration will be added to the next update of FlashPro Manager.
Old Jul 8, 2010 | 08:32 AM
StocS2k's Avatar
Wow that's a quick spool...8psi at 3k
Old Jul 8, 2010 | 08:50 AM
robertjr314's Avatar
Nice results.. Will you guys be adding this to the hondata manager software?? I have the same setup with a couple other tweaks.. This will be a great map to start some tuning on..
Old Jul 8, 2010 | 09:07 AM
itlynstalyn's Avatar
This is outstanding! Great gains throughout the entire range. Makes me wish I had an 06+
Old Jul 8, 2010 | 09:39 AM
Hondata's Avatar
This calibration will be added to our software. First posted edited to reflect this.
Old Jul 8, 2010 | 10:00 AM
Thanks guys, I'm looking forward to this calibration.. I will use it towards my tune
Old Jul 8, 2010 | 10:07 AM
urBan_dK's Avatar
Looks like there is some boost creep. This would be exacerbated by a test pipe. Common issue on the Greddy kits. The internal wastegate needs to be ported to prevent creep, but as long as the tune accounts for it I don't see it being a huge deal here. I'm assuming a 10 lb. wastegate spring is being used?
Old Jul 8, 2010 | 02:41 PM
nightowl's Avatar
Honadata- do you guys have any HP# for an 08 ap2 Greddy kit.
Old Jul 8, 2010 | 03:00 PM
urBan_dK's Avatar
There's no reason that would be any different from an 06. They are the same car.
Old Jul 8, 2010 | 07:29 PM
its the same.
