Berk HFC in OEM-style
Hi guys
now i've got a Berk 70mm HFC - thanks to Bryan for this smooth transaction
it looks and fits very good, but due to very rigorous police controls in switzerland i decided to hide the HFC from foreign looks with the original heat shield
so i had to weld some brackets on the tube
here is the result:
Uploaded with ImageShack.us
i'm curious about how this HFC works in combination with the Ti-C single
greez
Patrick
here is the result:
greez
Patrick
^That's awesome! I think more HFC/Testpipes should have flanges welded on to give ppl the option of putting the stock heat shield on.
No, it looks like the op did that himself!
it's my own work
first i had to find the exact position and angle from the HFC to the heat shield
i fixed it together with a tape
then i cutted out cardboard to have templates for cutting out the sheets
put the heat shied on the pipe and mark the position of the little tube with a M18x15 thread for the O2-Sensor
drill a 5mm hole in the pipe
al last i fixed the sheet cutouts with tape at the upper part of the shield (see Pic 3) and then spot-welded it at the pipe
after this all sheets can be welded at the HFC
as you know someone who is good in welding stainless steel it really no problem
i took sheets of 2.5mm thick, so that most of the welding-heat goes on the bracket and so you can avoid burning holes in the pipe
if someone is interessted, i have the cardboard templates
i could try to make a drawing, scan it and load it up
BTW:
the Berk-HFC is awesome
the butt-dyno says the car runs as good as with the 70mm testpipe, but without smell and smoke
didn't think this HFC has so much flow - great!
and it sounds absolutely awesome with the Ti-C single behind it
Again many thanks to Bryan@BerkTechnology!
Patrick
BTW:
Patrick
