closee
Old Sep 12, 2010 | 07:23 AM
S2BOOSTED's Avatar
Default closee
close
Old Sep 12, 2010 | 07:27 AM
S2BOOSTED's Avatar
next i mounted the manifold and turbo.. ran into some problems with he down pipe.. had to bring it to the shop to weld everything together..
Old Sep 12, 2010 | 07:29 AM
S2BOOSTED's Avatar
today im going to mount the new oil pan which is tapped already and run all my oil lines..
Old Sep 12, 2010 | 08:14 AM
SRap1's Avatar
i was debating on picking up this kit before you did.... how'd you feel about cutting the crossmember?
Old Sep 12, 2010 | 10:06 AM
bluemetals2k's Avatar
wow you actually cut the cross member in half... ...I know there's other kits around here that don't require such a thing......i'd like to say I hope the front end doesn't suffer body roll or rigidity loss but I'm pretty sure it will
Old Sep 12, 2010 | 11:00 AM
kutsujula's Avatar
cut the crossmember out and put in a chromoly bar.
Old Sep 12, 2010 | 11:08 AM
Deception's Avatar
Old Sep 12, 2010 | 11:23 AM
m R g S r's Avatar
from the looks of it there is no room to mount a chromoly bar, or pipe actually, i doubt you'd want to use a solid bar there, it would probably weigh a hundred pounds or so lol
btw...theres no need for a fuel rail, don't waste your $ on it.
are you gunna move the fuse box too? looks like theres gunna be a lot of heat in that area.
Old Sep 12, 2010 | 12:24 PM
kutsujula's Avatar
I've cut mine out and put in a chromoly bar, weighs farrrrrrrrrrrr from 100lb's.
It's hard to see it in this pic but if you look in the front of the car.
Old Sep 12, 2010 | 12:44 PM
berlinas2k2's Avatar
Your intercooler is too small for anything over 450HP....Just an FYI
