idoling????
Old Oct 31, 2002 | 02:19 PM
speedfreak's Avatar
does anybody else's car almost stall sometime just after you start it or if you rev it a little at a light when it's cold??
Old Oct 31, 2002 | 02:44 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
MAP sensor or BATTERY, (believe it or not), are the most common. Check you vac lines and elect connections at the MAP, be sure batt terminals are nice and clean.
Old Oct 31, 2002 | 03:07 PM
xviper's Avatar
https://www.s2ki.com/forums/showthread.php?...50&pagenumber=1
Old Oct 31, 2002 | 03:25 PM
HARDtoTOP's Avatar
Yeah, it seems to be totaly normal. Goes away after full warm up right?
Old Nov 1, 2002 | 05:28 AM
demonderrick's Avatar
Max, it happened to me before, I always think it is the problem from map sensor or whatever..!! however, I changed my spark plug after 20K miles...that stall goes away for a long time... maybe you can consider changing the spark plug..
Old Nov 1, 2002 | 05:49 AM
Pinky's Avatar
I had the same issues just as the temps dropped! Not sure if this is the same. Pull the backup fuse under the dash for 1-2 min. This will let it re-learn the new temps. After 1 day it didn't do it again. Idle is normal now. Or you can grab a screw driver and use the handle end to tap the map sensor a half dozen times. Helped me onetime.
Old Nov 1, 2002 | 01:10 PM
Vrm Vrm's Avatar
My car does this kind of Idoling once in a while...
Old Nov 1, 2002 | 04:02 PM
speedfreak's Avatar
hey chip
Old Nov 1, 2002 | 04:06 PM
speedfreak's Avatar
i'll try xviper's idea on the outher thread and unplug my ECU fuse for thirty seconds.
unless anybody has any better ideas???
Old Nov 1, 2002 | 06:10 PM
how do you have time??
Day_One
Dec 28, 2016 01:20 AM
Moddiction
May 25, 2015 08:52 AM
tdli
Dec 10, 2008 10:10 PM
j8mie
May 14, 2007 10:36 PM
Kekoa
Apr 15, 2004 05:32 AM
