Anyone with the driver's side window that drops 2" when dropping the top?
Old Nov 7, 2002 | 03:41 PM
lucid's Avatar
Default Anyone with the driver's side window that drops 2" when dropping the top?
After 11k miles my driver's winder stopped auto dropping when the top goes down or up drops about 2" - not all the way. Works fine by its own switch and the passenger's drops no problem. Which would lead me to believe it's a fault in the convertible module. I haven't done any probing I'm just having the honda tech's deal with it. Is this module the source of the problem (I think it is)? It's not that I'm lazy, its just I don't have time to troubleshoot.
Was there a TSB on this? I see others with the same issue
Old Nov 7, 2002 | 03:45 PM
Stratocaster's Avatar
Yes, that is the TSB one. I have had it twice so far and the Dealer told me that they changed the part from the June part number to the Oct part number. It should be fixed now, but only time till tell.
Euclid's Avatar
I had this exact same problem with mine (4000 miles).. I took it in and they replaced the window regulator motor, and now it works great.
Old Nov 7, 2002 | 03:47 PM
djvtecs2k's Avatar
yes i had it happen at 5k and its happening again at 10k the dealer said it was common and its the auto switch on the driverside. you said that the autoswitch works fine i think thats wierd. anyway take it in dealer should fix it
thanks
LArry
Old Nov 7, 2002 | 03:50 PM
wickerbill's Avatar
Mine just started doing this recently along with the colder weather. I just got my car in July and since people have been reporting this problem for well over a year I would have thought it would have been resolved by then. I guess I'll need to take my car into the dealer.
Old Nov 7, 2002 | 03:51 PM
ssanae77's Avatar
The receipt I was given after I had mine fixed
Old Nov 7, 2002 | 03:52 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Definite TSB. Involves replacement of the drivers side window regulator assy. Go tell the to fix it!
Old Nov 7, 2002 | 03:53 PM
Dallas's Avatar
It is not the switch, it is the motor/regulator.
Old Nov 7, 2002 | 03:58 PM
silverstreakn's Avatar
Had the same problem within the first six months!
Old Nov 7, 2002 | 04:00 PM
krazik's Avatar
Administrator
The S/B in that scan are the TSB numbers. i can assume "S/B" = Service Bulletin. The numbers look right.
01-008
01-013
