2004 can not be pushed forward/ backward.....nor shiftable
Old Aug 7, 2020 | 11:38 AM
Flipper1's Avatar
Default 2004 can not be pushed forward/ backward.....nor shiftable
New owner...been running awesome for 1500 miles..... went to drive today....will not engage into gear nor can I push car fwd/ backward...appears as if car is stuck in gear.....undriveable.....ugh....HELP from pros please
Old Aug 7, 2020 | 12:05 PM
engifineer's Avatar
Questions
Will it shift into gear when not running?
What happens when trying to shift when it is running? Does it grind when you try or does the shifter just refuse to move?
Can you push the car when the clutch pedal is depressed whether running or not?
Clutch pedal feel normal?
Old Aug 7, 2020 | 12:22 PM
Flipper1's Avatar
Yes...shifter moves normal into all gears running or off...car will not push running or not, clutch depressed or not....clutch feels totally normal
Old Aug 7, 2020 | 12:47 PM
engifineer's Avatar
Ok, so you can select gears when the car is running and clutch in then it sounds like. So I am going to say based upon that your clutch and transmission is fine.
Jack up the rear of the car, place car in neutral, release ebrake and try turning the rear wheels by hand and tell us what happens. Could be a stuck caliper which is more common on the rear brakes of this car. If so one wheel will not turn by hand and that could be your issue. Just make sure the hand brake is released of course.
Old Aug 7, 2020 | 04:06 PM
NNY S2k's Avatar
^^^^Great advice.
Levi
Old Aug 8, 2020 | 03:46 AM
Flipper1's Avatar
Default Reply
Yes!!!!!!.... Indeed it is or was a stuck left rear caliper...... advice?????..... will this be dragging while driving....other words should I repair prior to driving further????....Thanks for the great advice
Old Aug 8, 2020 | 10:24 AM
NNY S2k's Avatar
Yes.
Levi
Old Aug 17, 2020 | 06:41 AM
blueosprey90's Avatar
Absolutely. Dragging brake pads lead to overheating and seized brake pads. You need to investigate, including potentially the brake lines, and possibly even the master cylinder. Work your way backwards until you find the problem.
Old Aug 17, 2020 | 10:21 AM
engifineer's Avatar
Betting it is a stuck slider pin. If you can get it freed up without damaging it you may be able to clean it up, grease it and resolve it that way. But if not, a new caliper is required.
NavyTrev
Apr 5, 2019 03:54 AM
avlis
Nov 12, 2018 02:03 PM
f20rob
Aug 23, 2018 11:34 AM
