2004 can not be pushed forward/ backward.....nor shiftable
New owner...been running awesome for 1500 miles..... went to drive today....will not engage into gear nor can I push car fwd/ backward...appears as if car is stuck in gear.....undriveable.....ugh....HELP from pros please
Questions
Will it shift into gear when not running?
What happens when trying to shift when it is running? Does it grind when you try or does the shifter just refuse to move?
Can you push the car when the clutch pedal is depressed whether running or not?
Clutch pedal feel normal?
Ok, so you can select gears when the car is running and clutch in then it sounds like. So I am going to say based upon that your clutch and transmission is fine.
Jack up the rear of the car, place car in neutral, release ebrake and try turning the rear wheels by hand and tell us what happens. Could be a stuck caliper which is more common on the rear brakes of this car. If so one wheel will not turn by hand and that could be your issue. Just make sure the hand brake is released of course.
Yes!!!!!!.... Indeed it is or was a stuck left rear caliper...... advice?????..... will this be dragging while driving....other words should I repair prior to driving further????....Thanks for the great advice
