Buying a 2000 s
Old Jan 26, 2006 | 03:26 PM
shakes's Avatar
Default Buying a 2000 s
Hi Im interested in a s2000 its a 2000 is there anything specific I should be looking for in regards to engine tranny convertible top recalls/issues with this year, thanks in advance thinking of buying it soon.
Old Jan 26, 2006 | 04:56 PM
TheCarGuy2021's Avatar
newer 4 hole oil banjo bolts and a new window regulator are all ive had problems with in my MY00
Old Jan 26, 2006 | 05:17 PM
shakes's Avatar
But do u have a buzzing noise from tranny and would a newer clutch fix the problem
Old Jan 26, 2006 | 07:09 PM
vtec9's Avatar
The buzz you are referring to, I'm assuming on decelleration, is coming from the clutch. It's common on MY00 S2000s. There was a TSB issued for it, which means its documented by Honda, however its not really a problem. There is no loss of performance, and no harm is being done to the car. The clutch isn't going to break.. just make a lot of noise. The only reason to replace the clutch is if you can't stand the noise.
Old Jan 27, 2006 | 04:38 AM
shakes's Avatar
So if I do replace the clutch the noise would go away.
Old Jan 27, 2006 | 04:53 AM
vtec9's Avatar
If the noise is in fact clutch buzz, yes it would go away. I think the noise is pretty unmistakable and eminates from behind the radio. Like I stated before however, no harm is being done.
Old Jan 27, 2006 | 06:37 AM
Wisconsin S2k's Avatar
moving to S2000talk
Old Jan 27, 2006 | 07:44 AM
wanabe's Avatar
i think the noise depends on whether you are top up or top down...
i never hear the noise in my '00 causes the top is almost never up.
on the very rare times that it is up, i do hear the noise.
but then, my spugen exhaust pretty much takes care of any noises!!
i suggest that you take the car to your honda dealer and ask them to check it out and especially check to see if the tsbs have been done (spark plug tsb and seat belt tsb are prob the most important ones).
my drivers side window regulator has been out for several years now, so it doesnt drop by a single touch. i have to operate it like the passenger window (hold the button down)- not a big deal to me, but it was a problem on the early model years (again, only if it bothers you).
Old Jan 27, 2006 | 08:56 AM
hkspwrsche's Avatar
[Hi Im interested in a s2000 its a 2000 is there anything specific I should be looking for in regards to engine tranny convertible top recalls/issues with this year, thanks in advance thinking of buying it soon.]
This looks almost like a set up for a "Whos on first" ramble..
Old Jan 27, 2006 | 09:11 AM
S2Kiowa's Avatar
On the home page of this website go to the "Under the Hood" section. It lists the 5 "problems." (None of them affects performance only personal preference.)
