Checking oil, which side of dipstick?
Old Sep 18, 2007 | 05:37 AM
  #21
Lionheart's Avatar
Originally Posted by specialk22tt,Mar 20 2007, 08:48 PM
^ If you check it when it's cold, it will give you a skewed reading because the oil expands when it heats up. So, you may be overfilling the oil by reading it cold. The best time to read it is about 10 minutes after you've shut the car off on a level surface.
I do the same. Let it warm up fully and after stopping wait for some 10 minutes. It's OK if the drivers side reads a little low compared to the other side, just take the lowest side and remember, overfilling is as dangerous as too little oil
Old Sep 18, 2007 | 05:39 AM
  #22
Lionheart's Avatar
Originally Posted by Dizzymon,Sep 17 2007, 11:33 PM
How many times do you have to add again? I don't drive aggressively or anything but each time I check it after about 1k mile of driving I don't see any oil on the stick at all. I've got Mobile one Synthetic in there but I've tried so many times to get an accurate reading. So far no luck!
Is there so little oil in the engine or is the oil still that light of color? Be sure to have enough oil in it!
Old Sep 18, 2007 | 06:54 AM
  #23
Dizzymon's Avatar
I think I put in 4.25 quarts of oil during my last oil change and added an extra quarter after about 2k miles of driving because it looked low one day when I was checking the oil levels. It's been 2k miles already and it's happening again. I'm going to do an oil change this weekend and see what happens. The oil light isn't lit so I'm safe I guess.
Old Sep 20, 2007 | 03:44 AM
  #24
Lionheart's Avatar
Don't trust the oil light, trust what the dipstick says!
Old Jun 12, 2011 | 07:56 PM
  #25
neerredd's Avatar
im still confused, so whats the point of the cold check if you do the hot check, do i add oil if the cold reading is on low, or if the hot reading is low, because the hot reading was on full!
Old Jun 17, 2011 | 08:39 AM
  #26
Lane03's Avatar
Holy old thread batman! If the hot reading says your full then you are fine.
Old Jun 19, 2011 | 11:56 AM
  #27
redlineracing's Avatar
When you do a oil & filter change,just pour in 5 qts.That's close enough.
BTW,on my 03(78k miles) I never have to add oil between changes.
\rlr
carolina
Old Aug 13, 2011 | 04:11 PM
  #28
Chazmo's Avatar
Pretty funny the level of anality that we used to have about nonsense like this.
relineracing, 5 qts. never gets me to full. And, on my MY02, I always have to add oil every couple of weeks. My compression is great, by the way, as testing at 100K mi, but it has always burned oil.
Old Sep 22, 2011 | 09:09 PM
  #29
Breaking Point's Avatar
Checked my oil tonight at the gas station after fillup and was kind of confused one side was above full make and other was at little under half mark
Old Sep 23, 2011 | 02:16 PM
  #30
Chazmo's Avatar
That seems way off, Breaking Point. Probably you didn't really clean off both sides of the dipstick before pushing it in.
