Finally got my S2000
Old Aug 14, 2009 | 10:50 AM
kimimila's Avatar
Default Finally got my S2000
Finally, after 6 mos of fights with my significant other, I have been dealing with the "you get what you want, but not when you want it". Now I am a proud owner of a 2006 SK2, silver with black interior. Noticed that some of you guys have taken of the Honda emblems, what is the easiest way to get these off without ruining the paint? Also, since this car is used the trans syncros are a little worn going from 1st to 2nd gear, after engine warms up - no problem, is this common? car has 32K miles on it.
Old Aug 14, 2009 | 11:34 AM
s2k>wrx's Avatar
the 1-2 grind is what happens when your trany is cold when it warms up its better, just to make shure you could change the trany fluid, welcome
Old Aug 14, 2009 | 01:29 PM
negcamber's Avatar
Welcome!!
Which emblems are you talking about? The "H" on the nose and trunk? Or the "S2000".
You will need to get a bodyshop to do the "H". If you remove them, they leave holes behind that need to be filled and painted.
The "S2000" emblems can be removed with dental floss and then use bug & tar remover or GooGone to get rid of the remaining adhesive.
Old Aug 14, 2009 | 02:19 PM
jonner's Avatar
and welcome......
Old Aug 14, 2009 | 06:50 PM
takeshi's Avatar
Yup, normal. Change fluid more often then recommended to help but it can still grind when cold. Go easy on it until it warms up.
Also, moving the seat forward helps many people.
Old Aug 21, 2009 | 09:01 AM
tntrac's Avatar
Whats is the recommended interval to change transmission fluid?
My 07 does it also. Drives me crazy.
I only 17k miles. but it does that since I had 6 k miles when I first bought her.
Tony
Old Aug 21, 2009 | 07:28 PM
takeshi's Avatar
30K IIRC. I change mine every 15K and it shifts significantly better after each change.
Old Aug 21, 2009 | 10:04 PM
ziggy55's Avatar
welcome!
Old Aug 23, 2009 | 12:00 PM
s2k>wrx's Avatar
yup about 15k intervals are good for the s2ks tranny fluid
Verichai
Feb 27, 2025 10:10 AM
FastS
Dec 10, 2016 07:25 AM
fdf074
Jan 20, 2006 07:46 AM
WeekendWarrior
Apr 2, 2003 04:49 AM
jlee33
Oct 17, 2002 09:55 AM
