S2000 dillema
Old Jun 22, 2014 | 12:41 PM
Sly.'s Avatar
Default S2000 dillema
Hello! Im new to this community.. i own a 08' mx5 with a PRHT (1.8 litre ) . The last few weeks im intrested in bying an S2k Ap1 (cant afford an ap2). I want to specify that i have to sell the mx5 in order to buy an AP1.I am just worrying to swap in a much older car and it will be difficult to find an un-molested one on my budget.. till how many miles (car mileage or the cars km since im european) should i look for before i have compression problems etc.? Just Looking for opinions for the car swap and advices! thank you all bedorehand!!
ups... dilemma*
Old Jun 22, 2014 | 12:53 PM
cdelena's Avatar
If you are looking for an AP1 try to get an '02 or '03 with less than 80K miles. An unmodified car with a conservative owner can be almost as good as new.
Old Jun 22, 2014 | 01:14 PM
Sly.'s Avatar
Actually i think i have found a good deal with 37k-55k miles but both of them are 01' anything i should be careful about 2001 models?
Old Jun 22, 2014 | 09:37 PM
Gotpepsi's Avatar
Just make sure that the top has a glass window instead of a plastic window. A glass window indicates that the top has been changed. Nothing wrong with a plastic window of its in good shape; but I'm sure you prefer a glass window. There are no significant differences between an 01 and 02-03.
Old Jun 23, 2014 | 02:57 AM
mosesbotbol's Avatar
Look in the engine bay to make sure everything is OEM, along with exhaust. Make sure you know what body panels have original paint. Use a paint depth reader if you can.
I would not worry about compression on an unmolested car at all.
Old Jun 23, 2014 | 06:19 AM
deepbluejh's Avatar
Honda made continual small improvements over the course of the run. There are no years of S2000 which have serious flaws to look out for. The earlier ones have a few more small issues, but nothing that should dissuade you from getting the car.
I would try to avoid the '00 model year, as they had the plastic rear windows which were prone to rapid wear.
Old Jun 23, 2014 | 08:37 AM
Sly.'s Avatar
Thank you guys !! Anyone know the cost of the hood with a glass window in case the one i find has a plastic one? ( if it needs repair)
Old Jun 23, 2014 | 08:42 AM
vader1's Avatar
I guess I would respectfully disagree. Over-rev will show up in a compression test. An unmolested car could still have been overreved and will need the retainer job or it will go boom in the future. Even a pretty conservative driver could have done a ham fisted missed shift into the wrong gear.
Over rev, second gear grind are probably the couple things I would look for. Otherwise they are pretty bulletproof.
Old Jun 23, 2014 | 08:47 AM
vader1's Avatar
Glass window is preferred BUT, plastic polishing both sides of a foggy one will do wonders. I thought mine was ready for the trash and used a good plastic polish and now looks almost new.
The stock plastic window unzips and you can buy just a new plastic window for maybe a couple hundred Euros, but you have to remove and reinstall the top which is long afternoon.
https://www.s2ki.com/stor/library/TSB/A00-048/index.htm
Old Jun 23, 2014 | 11:46 AM
Have you compression tested every car you ever bought? The vast majority have not and haven't had an issue.
