What to look for when buying used.! HELP!
Old Oct 21, 2015 | 09:30 PM
Damian_mayker's Avatar
Default What to look for when buying used.! HELP!
Hey everyone again, i am still very new and i am 2 weeks away from my first s2000 i have never driven one or sat in one but I'm saving that sentimental moment when i purchase the car.... anyways i was wondering what do i have to look for when i am going to purchase this used car ... it is a 04 and i remember seeing a list of something a long time ago but i can't seem to find it again.... anything helps and hope everything goes well and l get the car a spread my love for it!!!
Thank you
Godspeed
Damian
Old Oct 21, 2015 | 10:41 PM
Max88's Avatar
This should help
https://www.s2ki.com/s2000/topic/775...-a-used-s2000/
Old Oct 21, 2015 | 11:59 PM
niveK's Avatar
Originally Posted by Max88
That post contains a lot of great information, Max88. I would also recommend for you to read this post after you buy your S2000, Damian_mayker! Don't forget to share pictures of your new ride!
https://www.s2ki.com/s2000/topic/102...replace-first/
Old Oct 22, 2015 | 03:33 AM
Chuck S's Avatar
Note Honda tweaked the car regularly during the production run. Mainly to cure the oversteer problems. Not surprisingly the later models are better drivers than the early models in many respects. The '06+ generation offers DBW (drive by wire) which allows power tuning without modifying the car or buying an aftermarket ECU. The amount of mid-range torque available this way is reason enough to look for that generation. VTEC at 3,600 rather than 6,000 rpm puts a lot of power on the road. Also has stability assist and traction control which will keep the car under more control when you get silly or inattentive. Purists can switch this off.
-- Chuck
Old Oct 22, 2015 | 07:03 AM
Jdrum1's Avatar
You may consider checking your local subforum to find a "mentor" that may be able to help you search and inspect potential cars.
Old Oct 22, 2015 | 10:28 AM
mongomery1234's Avatar
As people have said the newer DBW cars are better cars but the older ap1's are better s2000's. Just depends what kind of experience you're looking for.
Old Oct 25, 2015 | 05:48 AM
Themikewoo's Avatar
Welcome.
Thanks niveK for the plug in my signature.
krausean
Mar 18, 2014 02:47 PM
ADiSKOTEC
May 24, 2007 10:18 PM
Christople
Jun 1, 2006 07:20 PM
