CR Conversion
Originally Posted by dan_uk,Sep 19 2008, 06:36 PM
its kinda more a type-s than a CR you are making
http://www.s2kblog.com/2008/07/japan-gets-...a-s2000-type-s/
if you do the headlights you should clear out the old ones I reckon you could sell them on for a decent price
the CR is postioned between the Type R and Type S according to Shigeru Uehara.
You Tube vid
1:09 in the video.
i would love to find the suspension specs on the Type S, i wouldn't be surprised if it is the same as the CR. it would be nice to verify.
You Tube vid
1:09 in the video.
Quick question from the tire guys. Will a 255 tire fit on this rear wheel? http://www.tirerack.com/wheels/WheelCloseU...=All&sort=Brand
Originally Posted by speedworksracing,Sep 10 2008, 11:04 AM
CR struts are not adjustable.
I did the CR front end. It is really nice and looks great, also you cant go wrong with factory honda parts that you know will fit the first time.
DONT FORGET.
If you do the AP2 headlight you need AP2 Balasts for the HID's. Also the AP2 bumpers use a differant tow hook cover than the AP1. And if you want to keep the AP1 fender liners and front undertray you have to zip tie them up cause they do not match the AP2 bumper. The Front bumper you buy from Honda does not have a grill in it and you have to buy one for the AP2. The lip will come painted, so will the tow hook cover but the bumpers come in primer. You can use the stock trunk but you have to cut large holes in it to put the wing on and then you have to get these little side rubber pieces to keep it from shaking real bad. If there is anything else I can think I will post it up.
DONT FORGET.
Also, if you convert the front bumper, Hardtopguy has a fender liner kit they sell that allows you to use stock fender liners and have everything fully covered, without using zip ties.
+45 is going to be close...I'd say it's a risk.
If it is the price that's the concern, pick up some used AP2 rims. Otherwise the TRMotorsport F3 is a good choice that's the same size and offset as stock.
, roll the fenders, play with the alignment and you're all set.
