Jacksonville 1st Coast S2000 Owners
CR Conversion
Old Sep 25, 2008 | 07:28 PM
  #61
Righteous_Spec's Avatar
HEY HEY ....we all need 255s!
225/45 255/40 is the perfect stance if you make it 245/40's they will be shorter in the side wall then the 225s
Old Sep 25, 2008 | 07:30 PM
  #62
jphish's Avatar
I don't understand why they won't work.
Enkei wheels specs. Requires fender rolling
17x7.5
Offset: +48mm Backspacing: 6.10" Bolt Pattern: 5-114
Rec. Tire Size:205/50-17
Weight: 15.2lbs.
Est. Availability: 10/24/08
Rear Fitment
17x8
Offset: +45mm Backspacing: 6.22" Bolt Pattern: 5-114
Rec. Tire Size:225/45-17
Weight: 15.6lbs.
Kosei
17x7
Offset: 50mm Backspacing: 5.98" Bolt Pattern: 5-114
Weight: 13.7lbs.
Est. Availability: In Stock
Rear Fitment
17x8
Offset: 45mm Backspacing: 6.26" Bolt Pattern: 5-114
Weight: 15.4lbs.
It's only a two mm difference on the fronts. What am I missing?
Old Sep 25, 2008 | 07:35 PM
  #63
Are those the tire sizes you want to go with?
225s have a larger contact patch than the 7" wide wheel....I"m worried about the push of the tire needing the fenders to be rolled or worse spacers (so we wont hit the insides of the suspension) with the offset being so high on the +50s
Old Sep 25, 2008 | 07:37 PM
  #64
jphish's Avatar
No. I called tirerack and they said that a 225 and 245 tire front rear would fit on the wheels. I am just really confused by this entire wheels thing. I need pictures or something.
Old Sep 25, 2008 | 07:38 PM
  #65
http://www.1010tires.com/WheelOffsetCalculator.asp
punch in your numbers
17x7 +36
17x8 +45
Damn Near Perfect match
I hope this helps
Old Sep 25, 2008 | 07:40 PM
  #66
jphish's Avatar
When I said I don't understand the wheels and tire thing I wasn't joking.
Old Sep 25, 2008 | 07:44 PM
  #67
Call me we'll talk it out on the phone....its almost confusing post per post
(904) 962-0357
Old Sep 25, 2008 | 08:03 PM
  #68
jphish's Avatar
I've seen the light.
Old Sep 27, 2008 | 06:12 AM
  #69
lucky3underworld's Avatar
Hey james you got pics of those wheels you told me you sere getting?
Old Sep 27, 2008 | 08:54 AM
  #70
jphish's Avatar
Originally Posted by RedS13,Sep 25 2008, 11:03 PM
http://www.tirerack.com/wheels/WheelCloseU...98&autoModClar=
that is where it is is at good sir and at $146 retail priced!
