Jacksonville 1st Coast S2000 Owners
How difficult is it to replace . . .
Old May 11, 2010 | 11:02 PM
zbrewha863's Avatar
Default How difficult is it to replace . . .
The clutch master cylinder and slave cylinder?
Apparently both of them went out. Honda wants like $600 to replace the two, and I don't have the money, so I just ordered the parts (which came to $165 shipped for both) and I'm planning on installing them both.
My dad will be up this weekend, he apparently has the specialty tool for the cotter pin on the master cylinder. From what I hear, that's the only hard part of the job. Has anybody here tackled this before? How difficult is it?
Old May 12, 2010 | 03:37 AM
Ryuu's Avatar
in my lifetime... oh yea... done this on more MG's Triumph's and Jag's then i care to remember... our car looks very simple...
Old May 12, 2010 | 04:12 AM
jimreaper's Avatar
I swapped out a few ap2 slaves to the ap1 slave. ( if anyone has a ap2 I recommend this swap ) The slave is easy. under 30 min.
As for the master I have not replaced one. good luck.
Old May 12, 2010 | 08:15 AM
axhandler's Avatar
good xviper DIY for the clutch master from another forum...
http://forums.s2kca.com/showthread.php?t=15696
and if you look you can find the Honda shop manual online pretty easily.
Old May 12, 2010 | 01:14 PM
AzN Tim's Avatar
Call Josh im sure he knows how to replace them.
Old May 12, 2010 | 02:57 PM
dc2-2-ap1's Avatar
slave cylinders are really easy but i don't know about the master cylinder. i don't think it would be that difficult- i have a shop manual
Old May 13, 2010 | 01:16 AM
zbrewha863's Avatar
Yeah thanks, I saw that xviper DIY, which is what inspired me to tackle this thing. I've never owned a manual before I got the S, so I've never had to do this before. And I know xviper knows a ton about mechanic work, so just b/c he can do something doesn't mean I can . . . .
I've done pretty much everything else besides internal engine or tranny work (even though I currently pay for oil changes -- homeowner's association is on my back), so I know a decent amount, but I've never worked on any part of a transmission or clutch system so I don't want to F it up.
The part that really worried me is that the clutch engagement point might switch afterwards. I don't really understand how to adjust it w/ the rod/nut in the master cylinder, and I don't want to mess anything up there. The system was bled two days ago, and now the engagement point is pretty much as soon as the pedal moves. So I would like that to change back to where it was (in the middle somewhere), but not sure I want to tackle it myself.
Which reminds me -- Honda of the Avenues (who diagnosed the problem) were really cool and they bled the system for free while it was getting brake work done, since I couldnt' afford to pay them for the master cylinder/slave cylinder job too. So props to them, I know none of the s2ki people work there currently but they are still taking care of us so that is really cool.
Old May 13, 2010 | 09:05 AM
axhandler's Avatar
True but you have us!! There are people in JAX that can disassemble an entire S2000 with nothing more than a combo wrench and a can of WD. j/k - but seriously
Are you positive that both of those NEED to be replaced? Seems very unlikely that they are both bad at the same time. I guess if you bought the parts you might as well install them.
Are you saying the engagement point changed after HOA bled the system? If so the new cylinders will likely correct the problem.
BTW - I bet Jeremy could hook you up with a Honda Tech that could do the work on the side for you. You know Jeremy, right?
Old May 13, 2010 | 02:47 PM
zbrewha863's Avatar
I know Jeremy, I heard he moved to Cali though? Either way, I'm not sure if this is difficult enough, or enough of a pain, that I should pay someone else to do it. It seems like about 1-2 hours of work, most of which is bleeding the system.
HOA told me both needed to be replaced, so on their word I bought both parts before getting a chance to check it out (wanted the parts here in time for Friday). I was checking out some other threads and it seems that everybody who does the master cylinder ends up either disassembling the slave cylinder and regreasing it/polishing it, or just replacing it. I don't have time to take it apart Friday (my graduation is Saturday) and I don't have a dremel to polish the nipple, so I thought it was best to just trust HOA and replace it.
Old May 14, 2010 | 01:46 AM
AzN Tim's Avatar
Call Rocky, he use to work at Honda of the Avenues.
19044003325
