Jacksonville 1st Coast S2000 Owners
Hydrolocked Engine
Old Sep 1, 2010 | 05:01 AM
PrimoGen's Avatar
Wink
Originally Posted by chartz,Aug 31 2010, 09:57 PM
Do you think it would run me cheaper to rebuild the engine or buy s used one?
rebuilding one would let you upgraqde certain parts to make even a "stock" motor better...
studs, retainers, springs etc can all be upgraded and made to be better.
If you can drop coin on a "solid" used motor, you might get a "better" rebuilt engine for around the same price
Old Sep 1, 2010 | 07:47 AM
T-Man's Avatar
Except I would probably focus on bottom end. Plus there are always unknowns when purchasing a used motor. I don't know how much rebuilding the S would cost, but I know it was fairly cheap for the GSR motor (with me doing labor). Keep in mind you might not need to rebuild anything. I would have a look at the motor first to see what (if any) damage was done. Good luck.
Old Sep 1, 2010 | 10:29 AM
PrimoGen's Avatar
cost depends on who you know and what you want to do. I have gone through 2 rebuilds and both cost money but I decided to upgrade internals each time.... it comes down to clock hours and what you are charged per hour. A buddy with extensive knowledge (and you as a good helper) can get it done for pretty cheap. "off the street", in a shop and you are looking a decent amounts of cabbage.
A motor is a motor in most cases but the F20 has its own quirks and pitfalls...
I suggest a rebuild but find someone or a shop who has decent wrench time on the F20
Old Sep 1, 2010 | 01:13 PM
yarbrough's Avatar
Talk to Turbo Josh.
Old Sep 1, 2010 | 05:40 PM
gettin it's Avatar
Whats the status?
Old Sep 2, 2010 | 02:18 PM
chartz's Avatar
Originally Posted by yarbrough,Sep 1 2010, 01:13 PM
Talk to Turbo Josh.
Can you get me Josh's info?
Old Sep 2, 2010 | 03:49 PM
chartz's Avatar
Update: Found thast I'm leaking lots of oil from underneath! NOT A GOOD SIGN!
Old Sep 2, 2010 | 04:22 PM
yarbrough's Avatar
Sending text.
Old Sep 2, 2010 | 04:24 PM
dc2-2-ap1's Avatar
info sent.
where is the oil leaking from?
Old Sep 2, 2010 | 04:26 PM
yarbrough's Avatar
I sent him your number also.
