Phone mounts.
I've seen some of the local guys with different phone mounts and some of you were using modifry bracket. what do you guys use and do you recommend ???
I use the Modifry bracket. then buy a "belt clip case" that you like. I cut off the belt clip part off the back side. then mount it to the bracket.
Here are the ones that I use. I have one for running the phone naked. and another one that accepts a small case.
http://www.amazon.com/gp/product/B00..._detailpages00
I am running:
-Panavise radio bracket
http://www.modifry.com/index.php?rou...product_id=105
-Panavise offset tipper
http://www.amazon.com/gp/aw/d/B000TY...+offset+tipper
-Panavise phone holder
http://www.modifry.com/index.php?rou...product_id=106
I really like this setup. It angles the phone to where it is easy to see for navigation purposes. It does not shake a whole lot, and that is with Hardrace motor mounts and innovative 75a transmission mount. I will have a better review in a few days since I removed the transmission mount. The offset tipper moved it away from the radio door. It will open and close with no interference. So far I haven't had any issue with a passenger hitting it with their leg.
