Jacksonville 1st Coast S2000 Owners
s needs help
Old Feb 12, 2013 | 10:54 AM
hieus2k's Avatar
Default s needs help
Looking for a shop or persons who knows the s. Maybe a blow head gadket or valve adjustment. Thanks
Old Feb 12, 2013 | 11:17 AM
jimreaper's Avatar
Symptoms ?
Old Feb 12, 2013 | 01:19 PM
hieus2k's Avatar
Burn lot of oil, did the compression text at stsge 6 and it lost only 5% on all cylinder so. It consumed 1quart every 500 miles and it smoke it ass off. I think is the valve seal or possible head gasket.
Old Feb 12, 2013 | 02:01 PM
SigS2K's Avatar
If its valve seals, it normally only smokes at start up, after being parked for a while.
Old Feb 12, 2013 | 02:48 PM
hieus2k's Avatar
Yupe got thst symtom too but it comsumed 1quart every 500 miles. Any suggestions? ?
Old Feb 12, 2013 | 06:09 PM
Redline S2K's Avatar
Seals could cause your oil consumption issue.
Sent from my SPH-D710 using Tapatalk 2
Old Feb 13, 2013 | 04:34 AM
hieus2k's Avatar
Thank guys
Old Feb 13, 2013 | 06:32 AM
johnvidakiv's Avatar
Christian at Auto Techniques is very knowledgeable with the s2000. as far as an actual shop goes. For your future reference
Old Feb 13, 2013 | 03:50 PM
trackrat's Avatar
agree it could be the valve seals.
also, compression rings and oil rings are two different things. you can have good compression but bad oil rings.
any oil in the coolant reservoir?
Old Feb 13, 2013 | 03:57 PM
hieus2k's Avatar
I'll looI but I dont think so. I think the valve seal
