Jacksonville 1st Coast S2000 Owners
s needs help
Old Feb 13, 2013 | 05:13 PM
sik1's Avatar
its not ur head ....its your block scored cylinder wall...
Old Feb 14, 2013 | 04:13 AM
JohnsS2000's Avatar
way too much info missing to even speculate on what it is. smoke color, how is the car running, compression #s, CEL, miles and age, turbo/non turbo? You may have too much oil in the motor and the excess is burning off from overfilling.
A blown head or head gasket would cause oil in the antifreeze or antifreeze in the oil or both in both.
Old Feb 14, 2013 | 04:25 AM
bj@jjautowerks's Avatar
Seen your car at Mases, Ricky did compression tests, and he says he thinks its the valve seals. So he was going to do another test today. And who mounted your radiator fans on the condensor?
Old Feb 14, 2013 | 06:53 PM
hieus2k's Avatar
It was Oscar (auto technique) installed. Whats wrong with it?. I hope it just a valve sea Il already did the block once.
Old Feb 14, 2013 | 06:58 PM
hieus2k's Avatar
@John: it turbo and it not oil over fill im sure. Ill doue check on the intifreezer to see if there any oil, you guys are great help; thanks
Old Feb 15, 2013 | 04:29 AM
Your fans should be on the radiator, not the condensor. I could understand on front of the radiator, but theres none from what me and Ricky seen. And im thinking its the head needs new seals. Im going by there after work, so ill chat with Ricky again.
Old Feb 21, 2013 | 08:40 AM
hieus2k's Avatar
Thanks guys
Ryans S2K
Feb 26, 2016 05:40 PM
1SlowSi
Nov 29, 2012 06:25 AM
charlesardolino8
Sep 26, 2012 06:56 AM
crank
Jun 21, 2010 04:25 PM
jyeung528
Jan 29, 2007 01:36 PM
