S2000 Clutch Master Cylinder
Need on ASAP. Seems that the puddle I went through (I should say lake) messed up my master cylinder. Theory is that when I clutched in, it sucked up some water somewhere and when I clutched out, it could of pulled it in and having no where to go, blew the seals on the cylinder.
My clutch pedal has 75% travel and 25% clutch. But it alternates also to working perfectly fine or 50% travel and 50% clutch.
No one seems to carry one in town!
you can't just refill it if it is empty- you have to bleed the air out. you might have a hole in the clutch line, a messed up master cylinder or slave cylinder. I would try and narrow the problem down before you start ordering parts (it will save you a little money). have you noticed any leaking? the master cylinder will leak along the firewall or into the cabin of the car where the clutch pedal bolts to the piston on the master cylinder. .
Well Oscar went and checked something by the pedal and when he came out of my car his fingers were black..he said just fill it up and get a new clutch master..because it went out.
Yeah but I havent stalled but maybe 5 times since I've gotten this car. And the last time being the euro street meet at San Marco.
I've stalled twice since the cylinder went out tho. Just because there is no clutch. Lol
You can also see if any local store has a rebuild kit. They are normally less than 20 bucks, and easy to install. I used to rebuild them for integras, 240sx and once a 3000gt. If you or Derek need help, just call me.
