Suspension Theory
SHOCKS, SPRINGS, COILOVERS
For Street use, It really makes very little difference what suspension you buy. If you are looking for a soft ride, pick one with a low spring rate. Dampers, do make a difference here. However ride quality is mostly influenced by Mid to high shaft speed valving (mostly bump). And really good single ajustible dampers, ones that allow you to tweak your cars hanlding the best, Should only adjust low speed rebound.
And this is why what damper you choose for street use doesnt really matter... Because most if not all of these "coilover" companys run Single adjustible dampers that adjust both bump and rebound with the same knob, which is silly for any sort of tuning for handling. AND the dampers the do run adjust mostly in the Mid speed valving range, limiting their usefull ness for any thing other then tweaking your ride quality.
Sure
Sure
boyguan
May 27, 2013 11:30 AM
bkowa092
Mar 16, 2011 09:44 PM
goldsS2000
Feb 21, 2010 08:26 PM
Nice write up, Ryan. I know it was you writing it and not just a copy paste, because of all the spelling and grammatical errors.
