4 Pts RollBar
You have to remove and cut the back panels to fit in the roll bar. Also, you will to remove both seats (you don't have to but will be easier to access), cut the carpet a little to fit the 2 points which bolts to the floor. I would say around 2.5-4.5 hrs.
Its not particularly HARD to install, just time consuming. Its relatively straight forward - just take your time and do it right. I would highly suggest removing the seats - and youll need to remove the spare tire/convertible top tray too to gain access to the area in the back.
To install harnesses you will need a harness bar.
These are all easy to install. Just follow the directions and if you get stuck call Ben or Dickson at AJ to find out what you did or didnt do right.
Of course you can call me, Spacecowboy, tpAp1, faulkengenious, etc...
I just got a cusco 4pt rollbar installed on my car last Tuesday...it took about 2-3 hours. We weren't in a rush. I don't have my softop assembly so it was much easier to drill. Also, you won't be able to have space for your space tire anymore. (like it would matter since you're getting bbk). Like others said, it's pretty straight forward as far as drilling. You just have to make sure the bars mount on flat.
