AC compressor removal
Originally Posted by S2000_Europe,Aug 24 2007, 06:13 AM
the Honda S2000 CR comes with no A/C.. do you have a friend at honda to look which belt uses de S2000 CR?
Originally Posted by Tyraid2K,Aug 23 2007, 08:00 AM
took exactly what you had here to my local napa store,
ended up with 45 5/8, they had th 45 1/8 but no 45 1/2, so i went big with the possibility of a return,
you think im in trouble?
K=??
6 = # of ribs on the belt
HAHA!! it's for a VDUB!!
http://www.evwparts.com/Merchant2/merchant...ieselTimingBelt
Goodyear belts
http://www.goodyearep.com/productsdetail.aspx?id=3128
Originally Posted by Tyraid2K,Aug 26 2007, 11:46 AM
wtf are you doing SOHCmyDOHC, are you giving me reliable information?
I prefer to not be jerked around
And NO I'm not jerking you around. Search the Part #'s I posted on the board. If you don't believe me that's fine. Go ahead and spend time at the parts store looking for the right belt.
Go to the parts store and ask for the belt I number I gave you. If they are stupid then do it yourself. I gave you both equivalent part numbers since there are A LOT of dumb shiet parts people. Hell tell them you want a belt for a VDUB (application I posted). Fit it (tight fit) and let me know if I'm right.
Chime back when you go to the store and actually get the part I suggested. I'll be waiting.
Good luck.
Originally Posted by SOHCmyDOHC,Aug 26 2007, 11:08 PM
I have a 450k6 belt aka 6pk1145 and it fits perfect. I have it on my project F20C corolla. I dunno what problem you may be having finding the belt I suggested let alone fitting it. I found the belt by searching the forums. I googled it and I found out the application is for a VDUB... So I posted it. The OG members are the ones that posted the belt size not me.
Good luck.
Good luck.
I got the larger one since I guess I wanted it to be a bit easier to put on. We'll find out in a couple days if it works.
I always search and it always sucks...
The next belt up which you probably got is the 6pk155 or 455k6 will fit but will be loose. B 4 you take your OEM belt off note the location of the pointer of the tensioner. With your belt it'll be waaay to the right aka loose and your belt will squeal. My buddy got that belt and his squealed at high rpms.
Originally Posted by Tyraid2K,Aug 27 2007, 08:52 AM
see i did all that and this is what they came up with (went to napa), one of your numbers didn't make sense and the other one yielded the 45 1/8 and 45 5/8, no 45 1/2 out there,
Originally Posted by VAD,Aug 27 2007, 09:42 AM
6PK1145 and 450K6 both cross-reference to NAPA # 25-060450. It is 1160mm (45.685") imperial length, which is the outer circumference length. Sounds to me like you two are on the same page, but arguing anyways.
Thanks for making me remember another part number the 060450 PN.
I read the napa PN as 06 = ribs and 0450 the length in inches similar to my reference of 450K6 but backwards!! hehe!
