ARC cooling panel
Old Jun 6, 2007 | 05:11 PM
modMonkey's Avatar
Default ARC cooling panel
I tried to fit my ARC cooling panel last night. There are 2 tab points comming out of the car that prevents the cooling panel front seating correctly on the car. What are other people doing to solve this issue? I'm considering drilling holes, but I want to avoid that.
Old Jun 6, 2007 | 07:15 PM
Startrek's Avatar
what tabs take photos?
Old Jun 6, 2007 | 11:29 PM
modMonkey's Avatar
Look at where I circled. These prevent the panel for seating on the car. In addition, it prevents the radiator stays from seating correctly once the panel is on.
Old Jun 6, 2007 | 11:30 PM
modMonkey's Avatar
Click the picture, once the page loads in my album, click again and it will enlarge to a good size
Old Jun 7, 2007 | 02:39 AM
AlX Boi's Avatar
After examing my plate and your picture, I can't seem to figure out what those tabs are. There are 2 openings in the plate that allows for access to some holes, but nothing for your tabs. I don't recall seeing any tabs on mine. If other people can't figure out what the problem is, I'll take my plate off t0m0 to see if there's anything there.
The only problem I had was the OEM screws weren't long enough to hook onto the hole, so I got longer screws from Ace.
Old Jun 7, 2007 | 03:21 AM
modMonkey's Avatar
Thanks, for the reply. Maybe they got rid of the tabs in MY06?
Old Jun 7, 2007 | 03:46 AM
modMonkey's Avatar
Well this is Diez's famous car. It is MY05, and I still see the tabs
Old Jun 8, 2007 | 09:29 AM
GotRPMs's Avatar
I believe that those tabs are holding the black plastic airgiude to the rad support. I removed the airguide and i didn't have that issue when i installed my cusco plate.
Old Jun 8, 2007 | 10:00 AM
neveronlines2k's Avatar
I had the air guide still on there when I mounted mine and those tabs didn't really block the cooling plate at all. The plate is not going to sit perfectly flush. I did have to adjust the hood latch a little to avoid them making contact.
I also have removed the Air Guide and I believe those tabs are still there.
I think they are similiar to zip ties on the other end to hold wiring away from the readiator. I would not drill them out until you find out exactly why they are there. I doubt they are there just for looks
Old Jun 8, 2007 | 11:35 AM
F20_C's Avatar
I don't think they are for the air guide. I think they are the back end clips of a wire loom that runs under that strip of metal. I took a set of pliers and pressed and pushed the plastic nipple down so they are flush. My rad plate fits perfect now.
