ASM Cooling Plate
Old Aug 29, 2011 | 02:57 PM
learnerspermit's Avatar
Default ASM Cooling Plate
I bought an ASM cooling plate and tried to fit it today with a Mugen Intake and a J's Racing Type V Hood. It didn't fit at all, and I am thinking its possibly the hood not the plate because I can raise the hood latch until it works but then the hood sits really high. Anyone had any experience or know about this?
Thanks
Old Aug 30, 2011 | 09:25 AM
MugenAP2's Avatar
It is the hood and not actually the cooling plate I had the same problem with my J's hood. The latch plate on the hood protrudes where the bolts hit the cooling plate. I changed the bolts in the hood to a lower profile bolt head. It did not solve it due to the fact it still marred the plate.
Old Aug 31, 2011 | 10:10 AM
So it wont work
Old Mar 28, 2012 | 06:27 PM
rustybolt's Avatar
Just found out the same thing, unless you cut the hood.
Old Mar 30, 2012 | 05:34 PM
Y0N1P8T5R1F5A4T's Avatar
My J's racing type v hood was also in the way of my radiator shroud so I just adjusted the hood latch from the three 10mm bolts. Took me like 10times till I got it the way I wanted it.
Old Apr 7, 2012 | 08:36 PM
s2kslav's Avatar
had the same issue with my js hood and asm plate, i cut out a rectngle in the plate where the bolts hit, kinda sucked to do it but came out pretty good
Old Apr 17, 2012 | 04:43 PM
Can you post pictures of this please?
Old Apr 25, 2012 | 11:05 AM
Mr. Francesco's Avatar
Mine works fine with my OEM hood.
Old May 23, 2012 | 10:19 PM
slightly2ned's Avatar
I ran the ASM Cooling Plate for the Gruppe M intake + J's Type V hood. I needed to raise the latch & cut a small section of the opening of the hood latch area on the ASM plate to allow for proper clearance.
Old Jun 1, 2012 | 05:20 PM
I'd prefer to see the scratches then cut a notch off and see a hole.
henrwhy
Nov 23, 2011 06:27 AM
learnerspermit
Aug 30, 2011 05:25 AM
tmbkenny
Jul 12, 2007 10:43 PM
blackfx35
Nov 28, 2004 12:45 PM
