ASM Overfenders
Originally Posted by nichigo,Mar 20 2009, 08:18 AM
I feel like i can run a little more aggressive still tho...esp in the front. I'm probably gonna throw on a 5mm spacer and see if it's more flush without rubbing.
-Hunter
Originally Posted by BulletProofAuto,Mar 20 2009, 08:33 AM
I was actually considering a 5mm spacer for my fronts as well. Do have the fender liner extensions for your ASM fronts?
-Hunter
-Hunter
Originally Posted by nichigo,Mar 20 2009, 08:34 AM
no..i need them though because i'm sick of seeing teh fender liner edges. Aren't they expensive from ASM?
-Hunter
Originally Posted by BulletProofAuto,Mar 23 2009, 10:18 AM
Back when I was a customer I purchased them for about $300. They are probably around $350-$430 now depending on the current yen rate. I see you are running the Bridgestone Potenza, how do you like them? What is your width on those tires? I am currently running 245 - 275.
-Hunter
-Hunter
Originally Posted by 01S2Kevin,Mar 24 2009, 04:46 PM
Nichigo, so with your current offset and width and your 245 tires in the back, is there any rubbing at all?
cus they didn't fit the re30 17x9+35 with 255 R888(by much)let me know if anyone wants a pic?
