ASM radiator pannel problem
Old Jul 20, 2006 | 08:12 PM
Mr. Francesco's Avatar
Default ASM radiator pannel problem
So i decided to install my ASM radiator pannel tonight, and now my hood wont latch shut.
I tried moving the pannel around, making sure everything is aligned properly, but it still wont latch.
Do i have to adjust the hood latch itself?
Old Jul 20, 2006 | 09:22 PM
ASMspec's Avatar
Make sure everything is bolted down then you might have to adjust the latch itself. No biggy. I had to too.
Old Jul 21, 2006 | 06:11 AM
Originally Posted by JsAP1,Jul 21 2006, 01:22 AM
Make sure everything is bolted down then you might have to adjust the latch itselft. No biggy. I had to too.
How do you adjust the latch though Chris?
Like what am I trying to do with it. I would assume I have to raise it?
Old Jul 21, 2006 | 06:29 AM
RacerXI's Avatar
There should be 2-3 10mm bolts below the actual latch (in the hole). It's prob. easier w/o the panel on though. Loosen them up and start with small increments up or down and you'll figure it out rather quickly.
Old Jul 21, 2006 | 08:01 AM
Well the pannel is off the car now. Ill give it a try now.
Old Jul 21, 2006 | 09:53 AM
Ok, i loosened the three bolts and raised the latch up about a .5mm. When the hood is shut, it is still flush with my bumper. Everything fits fine with the pannel now.
My next question is, even though the hood is secured, is their a chance it will pop open while driving if i hit a bump since i moved the latch?
Old Jul 21, 2006 | 01:19 PM
RacerXI's Avatar
Nope. Just be sure to tighten those bolts back down. I had to raise mine up on my car almost a 1/8" to get the hood to close without forcing it. I'm pretty sure my car was in an accident prev. and the owners traded it shortly after. Oh well. Glad it worked.
Old Jul 23, 2006 | 02:34 PM
circa86's Avatar
you raised it .5mm? or 5mm? .5mm seems like a tiny amount to me
Old Jul 23, 2006 | 03:13 PM
to be honest im not sure why i typed .5mm.
it wasnt raised much at all.
Old Jul 23, 2006 | 07:32 PM
XclusiveAutosports's Avatar
Don't worry about it, I also had to raise my hood latch and no problems here.
