ASM radiator pannel problem
Old Jul 24, 2006 | 10:41 AM
neveronlines2k's Avatar
Old Jul 24, 2006 | 11:58 AM
Xplosiv's Avatar
Originally Posted by XclusiveAutosports,Jul 23 2006, 10:32 PM
Don't worry about it, I also had to raise my hood latch and no problems here.
That was what I did as well.
Old Jul 24, 2006 | 12:40 PM
cusco's Avatar
One of the issues with the JDM cooling plates is the hood cable retaining clips from the under side of the upper radiator support. Since the JDM hood cables are routed from the opposite side of the car, the provisions in most cooling plates are on the wrong side.
I know this is an issue with the Cusco ones because that is what we carry. I haven't had to adjust the hood latch to get it to fit when you push the clips down/out of their holes. The hood cable is not going to go anywhere, and the cooling plate sits flush with no issues.
I would suggest trying this, it may help with the fitment. I know it does for the Cusco plates, they fit great when you do this.
Brad
Old Jul 24, 2006 | 07:52 PM
Mr. Francesco's Avatar
Brad
so your saying leave the latch alone and just let the hood release cable sway free?
Old Jul 25, 2006 | 08:21 AM
cusco's Avatar
That is what I've done and it works fine.
Old Jul 25, 2006 | 09:02 AM
ASMspec's Avatar
Originally Posted by Guedo512,Jul 21 2006, 06:11 AM
How do you adjust the latch though Chris?
Like what am I trying to do with it. I would assume I have to raise it?
You just have to play with it for like 20-30 minutes to get it to line up as perfectly as you can get it. It may take longer but will work.
PM me for specific problems and I will address them for you.
Old Jul 25, 2006 | 10:11 AM
geists2k's Avatar
There are two rubber knobs up front around the panel that can be screwed up or down by hand.
Just twist them down some more and see if this works.
I did this after I installed my Carbing panel and the hood closes just like it did before.
Old Jul 25, 2006 | 02:50 PM
mav's Avatar
mav
I had to raise my hood latch a bit when I installed my ASM radiator plate as well.
indys2ki
Sep 9, 2011 01:27 PM
MugenAP2
30
Jul 9, 2011 09:33 PM
EpRAnGia
Feb 17, 2009 12:36 PM
mav
South Florida
Apr 17, 2006 05:20 AM
problem_child
Feb 23, 2005 09:48 AM
